Hello. I just tried to install my HP4280 software to my new system, running Windows 7, and the response is that this software is not compatible with Windows 7. Help!!!??
    Guru:
  • 1,833 Answers
Please go to HP website and get an Windows 7 compatible driver and software.
Windows 7 Driver 13.1.0 2009-12-05 209.69 MB exe http://www.siliconguide.com/drivers/download/829/ Windows 7 64-bit Driver 13.1.0 2009-12-05 209.69 MB exe http://www.siliconguide.com/drivers/download/829/
Posted on Nov 07, 2010
Hi, I have used printmaster premier 7.0 for a few years on my old computer and have loved the program. The problem I am having is I bought a new computer that runs windows 7. I tried to install printmaster...
the problem is that windows 7 is not compatible with Print-Master premier 7.0
The program cannot run on windows 7 because it wasn't programmed for it. This is why the error message comes up.
There is nothing you or anyone can do about this.
Sorry about this.
Regards.
Sep 15, 2011 | Mindscape PrintMaster Premier 7.0
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
How to install canon printer into window 7
Remove your Canon printer from the PC and uninstall the printer software. Now reinstall the printer software which is downloaded fromt he website or from the disc.Only then you must connect the Printer which will be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Mar 14, 2011 | Canon LBP 1120 Laser Printer
I need a driver for kworld tv tuner pvr 305u.... and my os is windows 7... how can i install the driver?..
You can download driver on this page
http://global.kworld-global.com/main/support_down.aspx?mnuid=1255&modid=14
If I could be offurther assistance, let me know. If this helps or solves the issue, please rateit and give a testimonial for my response.
Mar 03, 2011 | Computers & Internet
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
My computer died. Had to buy new & went to Windows 7. Several CDs that installed programs on Vista and XP now won't load. E.g., Lotus Smart Suite displays "error accessing the system registry", then...
I have Win7 and am running Lotus Smart Suite 95 with no problem except for Approach which pops a message that I ignore.
Did you got to the CD and tell the install/start to run as administrator?
Aug 13, 2010 | Computers & Internet
I have Printmaster Gold version 3. I have had it installed on windows xp I now have a new computer with windows 7 and would like to install printmaster gold. What do I have to do?
Is your PMG 3.0 on the software compatibility listing for W/7? Did you check it? Pleae check it here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If your software is Windows 7 compatible, the list will tell you ... it should run with no hitches. If PMG 3.0 is not listed, you can appeal to the Printmaster Company for a upgrade path.
There is a compatibility test you can run from within the above link that will tell you what on your 'old' computer will migrate to your new computer ...
Even thogh this response was probably not within your expectation, it is a viable response and I hope it assist you in solving your delima.
Thank you for your interest in FixYa.com
Jul 01, 2010 | Computers & Internet
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jun 20, 2010 | The Learning Company PrintMaster...
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
(make your program/application run with windows 7)
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
103 people viewed this question
jasbo
jasbo
