Question about HP VP6121 Multimedia Projector
Can i connect the projector to an amplifier for audio
Is there any way, an adapter or anything, that will allow you to watch tv through the projector?
TV AV out - RCA cable
to
AV in on data projector
if these ports exist on your Data projector and on your TV
as you did not provide make and model numbers of the devices for us to check if the input and output ports of your devices are available.
if only a vga in on data projector
and av out on tv
https://www.youtube.com/watch?v=F6vF_l3Dh9I
you need to amplify the audio out red and white cables of RCA and connect to speaker that amplify like computer speakers.
google search
TV AV Composite S-Video RCA In to PC VGA Video
Jan 23, 2017 | The Office Equipment & Supplies
Why can I hear 50 rear projection tv no picture yes on sound?
The projector and the audio system for the TV are completely separate. There are many reasons your projector may not be working, however it's failure will not always effect the audio which runs through it's own circuits and amplifier to the speakers. Think of this as if you had your computer's VGA out plugged into a projector and the mini audio output plugged into amplified speakers. One will not effect the other unless your problem is a loss of power.
Aug 28, 2014 | Televison & Video
How to connect speakers to projector
You first need to determine that you have an audio output available. then determine how loud you want it to be and what type of speakers you are going to use. You may have to preamp this and then to an amplifier and out to the speakers. If you give me a bit more, starting with whether or not you have an audio out, I can help you from there
Jan 06, 2013 | InFocus LP70+ Multimedia Projector
I have an panasonic pt-ae2000e projector, how do i get sound?
The sound must be sent to an external amplifier system and speakers.
Audio cables must be connected from each peripheral device directly to the audio reproduction system
Mar 21, 2011 | Panasonic PT-AE2000U Projector
HOW CAN I GET AUDIO ON THE PROJECTOR IF I CONNECT A DVD PLAYER TO IT??
hi, it depends how you connect the DVD to the projector. the projector itself has only one speaker (mono) - not so good for movies. the "audio in" is a mini stereo plug (same as headphones). you will need a RCA to mini stereo convertor - red/white (or red/black) RCA to mini stereo plug.
or you can connect a RCA to RCA (red/white to red/white) cable to an amplifier which is connected to speakers.
or just plain speakers, but you'll probably need a convertor cable from RCA (red/white) to a female mini stereo plug).
these cables are pretty cheap and can be bought in any Radio-shack.
hope it helps....
Dec 19, 2010 | NEC NP200 Projector
How do you connect projector to satellite receiver
Hi
A satellite receiver is no different to connect when it comes projector than a vcr, dvd player etc.
There will be Video out RCA plug normally yellow in color. There there are two chords for Audio. Normally Red for the right channel and white for the left. Both RCA. If your receiver is mono, you will have only one audio.
There are corresponding jacks in the projector. There might be a video out and audio out in the projector. You can ignore those.
If you use a amplifier, The connections will go from receiver to amp and from amp to projector. It is a good idea to have an amp in between. You don't have to send the audio to the projector (which normally is not great sound quality). Just use the home hifi for it.
So summary of ideal connection :
-Video out receiver in yellow RCA to video in projector.
- One or two Audio out (Red+White RCA) from receiver to your Hifi Audio in
Listen to Hifi and watch thru projector.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 24, 2010 | Epson PowerLite 3LCD Projector
How do you hook projector up to sound system
it is best to bypass the projector and have all audio going through an amplifier and speakers separate from the projector, and also, only have video going to the projector
Jul 12, 2009 | NEC VT60LP Projector Lamp for VT660,...
How do i connect my projector with my tv
A TV is meant as a video display device, not a source. As such, it might have an audio output to run to something like a home theater amplifier, but it would be a truly rare TV that has a video output as well.
What you should do is connect another device such as a VCR that can act as a TV tuner. You can run the VCR's video and audio outputs to the projector, tune in the channel you want to watch with the VCR's tuner, and you're all set. If you're on a digital cable system and have a converter box, you can use the outputs from the converter box instead of bothering with the VCR.
May 26, 2009 | Panasonic Videoprojector PT-LM1E...
Lost manual
The manual is available online quite easily. Just google.
As for the audio connection, this is one big drawback of the TDP ET20. it only has digital audio out so you can't connect it directly to headphones or ordinary speakers. You need a home theatre system or an amplifier that accepts digital audio. Or you need to buy a seperate digital to analog audio converter.
Big pain.
Jan 15, 2009 | Toshiba TDP-ET20U DLP Projector
HP VP6121 Multimedia Projector Logo
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
