Question about LG Dishwashers
ERROR CODE E1 FLASHING AFTER ACCEPTING WATER LG LD 2131SH DISHWASHER......NO FURTHER CYCLE
SOURCE: E1 Error Message
Just had the same problem.It is a common defect of the standard pump motor assembly and LG recognises it and sells the whole assembly for $38. They changed the type of motor and now is 120W instead of the original 45W. They also supply a modified bracket to fit the new motor.
Posted on Jul 30, 2007
  • 110 Answers
SOURCE: E1 error on LG - LD-4120M
E1 is a common error in the LG Dishwasher range and is usually caused by the failure of the circulation pump and/or the impeller.
The motor and impeller are a complete unit.
Often what happens is the impeller breaks on the motor shaft and doesn't spin, therefore doesn't pump water.
There is a pressure sensor which indicates the lack of pressure and shuts the machine down with the E1 error being displayed.
The lack of pressure can also be from a water leak (as the owners manual suggests) also a controller PCB fault may produce an E1 error, however, the pump problem is extremely common.
Unfortunately, I have had 5 pumps die in 4 years and my dishwasher is only used about 4 times a week.
Posted on Dec 27, 2007
SOURCE: E1 Error on LG Dishwasher (LD-2040WH)
Maybe the blockage is somewhere else. How about removing all the trays from the dishwasher, in other words, empty it from all racks and dishes and try it again
Posted on Aug 13, 2008
chargerhp
  • 813 Answers
SOURCE: LG Dishwasher LD-2050WH with HE error code
LG Told me the water coming in was to hot and to disconnect power for a few seconds and reset water heater to around 120 deg
Posted on Jan 31, 2010
SOURCE: e1 fault no manual
Hi, use this table to find and know more about codes.When you get into the link,scroll you will see all codes and solution.
(repairclinic.com/0078.asp).
Take care.
Posted on Jun 14, 2010
LG DISHWASHER LEAKING WITH E1 ERROR CODE.
Hi phtanner,
The E1 error can be fixed by following my Tip below:
L.G DISHWASHER E1 ERROR...
Follow these directions, and the problem will be fixed.
Kind Regards :-)
* If this solution helped you, please rate it.
Jul 28, 2011 | LG 24 in. LDF 7811 Stainless Steel...
LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
May 26, 2010 | Dishwashers
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
E1 code comes up on the display, but how do you solve this? ...
E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Feb 18, 2010 | LG 24 in. LD-12BW5 Free-standing...
I have a LG Diswasher LD 2050 with a trouble Code E1. The manual says "Water leakage in hose connection" "water is leak by damage" Ihave check and everything is Okay. It let water in and when it start...
The most common problem on an LG dishwasher when error code E1 is reported but there is no actual leak found is the problem of a natural syphon being created by improper installation of the dishwasher. Pretty easy to fix:  Either add an Air Gap valve (available at any hardware store for almost free) or follow the drain hose from the dishwasher to the drain. Raise the hose and attach the hose to the up onto the bottom of the countertop. Adding that "rise" eliminates the possibility for the syphon effect to drain the dishwasher before the drain cycle begins.
If the hose ever fall back down, the problem will return immediately.  Adding the Air Gap valve is harder but is far more permanent (and complies with construction codes that really should not be ignored.)
Apr 17, 2009 | LG 24 in. LD-12BW5 Free-standing...
H"E" code the E flashes
Did your problem get resolved? What did you find was the problem?
I would have expected to see an E1 error with the symptom you described. Thanks for updating me with what you find.
Dec 11, 2008 | LG 24 in. LDF 7811 Stainless Steel...
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
"E 1 code error
E1 is a drain error. On the unit prior to mar 07 LG had a problem with wires breaking in the door. Turn off power supply, remove door panel and look for wires stuck in the insulation. Check continuity of the wires, if broken, splice and tape. Place insulation between black insulation and wires to prevent reoccurence.
Sgt 48
May 24, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Dec 23, 2007 | LG 24 in. LD-12BW5 Free-standing...
Dishwashers Logo
918 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
