Question about Acer Aspire 5600 Series 5630-6951 Laptop
Battery alarm warning
When battery is low, i get no warning that the computer is going to switch off.
    Sniper:
  • 65 Answers
If u r using windows xp then u can solve it by doin dis..
click start>control panel>performance n maintance>
power option>alarms....
then u can set ur alarms accordin to u...
if dis solution is not useful send me email at shriii2@rediffmail.com
Posted on Jun 15, 2008
We replaced the batteries but the alarms are still beeping with the low battery warning.
Either the new batteries are out of juice, or they have been installed incorrectly.
Jun 06, 2014 | Universal Security Instruments Smoke Alarm...
Low battery warning
Open the Control Panel and select Performance and Maintenance then Double click on the Power Options . Click on the Alarms tab and make sure the boxes are checked to activate alarms in both the "Low battery alarm" and "Critical battery alarm".
Mar 26, 2014 | Acer Aspire One D270-1679 Atom N2600 1
I replaced a battery in my 2001 pontiac montana n the lights started blinking as if the alarm was going off.i hit the unlock n lock button n the blinking stopped. i have power,lights n radio but van wont...
It can be any of the car doors not got properly locked or the door is locked but the switch is not sensing the door locked. Open and close each door again properly.
Or else its problem with any of switch wiring getting in contact with alarm wiring causing it to happen.
And last thing alarm connections need to be inspected. It's getting short somewhere in between.
There are few help links with solutions, to troubleshoot these types of problems. I suggest going through these links.
Click the link below: ------
Volvo car alarm keeps going off for no reason
http://technoanswers.blogspot.in/2012/07/volvo-car-alarm-keeps-going-off-for-no.html
Alarm keeps going OFF
http://technoanswers.blogspot.in/2012/07/alarm-keeps-going-off.html
2009 Toyota Camry: Hood Switch causing Alarm to go OFF?
http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
Ford Pickup Alarm will not disengage?
http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
Mitsubishi Diamante: Factory Security Alarm will not go Off
http://www.howtorepairguide.com/2012/11/mitsubishi-diamante-factory-security.html
Toyota Avalon Factory Alarm will go off?
http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
Chevrolet Tahoe Hood open warning on dash and alarm sounds?
http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
These details will help.
Thanks.
Nov 28, 2012 | 2001 Pontiac Montana
1999 acura slx alarm
CAR ALARM ISSUES
Thanks.
Nov 28, 2012 | 1996 Acura SLX
I have a 200 Grand voyager and the alarm want go off but the van will start...what is the problem
The Alarm module is getting indicated.Inspect all the doors.Inspect the ignition and see if any other light is remaining on.
Try reset by disconnecting battery negative for 5 minutes then reconnecting
For more help go through the link below.Click the link :-----
Alarm will not disengage? http://technoanswers.blogspot.com/2012/01/ford-pickup-alarm-will-not-disengage.html
Alarm will go off? http://repairhelpcenter.blogspot.com/2012/01/toyota-avalon-factory-alarm-will-go-off.html
Hood open warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
Hood Switch causing Alarm to go OFF? http://whatisbyme.blogspot.in/2012/04/2009-toyota-camry-hood-switch-causing.html
This will help.
Thanks.
Jun 05, 2012 | 2000 Chrysler Grand Voyager
Our chrysler pt cruiser has a problem. Every couple of minutes alarm goes off and AIR BAG lights up. ?????????
Is your battery starting to loose its charge? Check and see. If the charge drops to low it resets the computer and the alarm goes off and various dash board warning lights sometimes go off. If that isn't the problem try pulling the fuse and check to make sure it isn't damaged or partially blown.
Jul 25, 2011 | 2006 Chrysler PT Cruiser
Keyfob problem
try changing the fob battery .the freelander has a fob low battery warning tone that will start after the alarm has been deactivated by the fob with a low battery and will stop after the key is switched to acc. for any one wanting info on problems with freelander , goto this web site . http://www.myfreelander.co.uk/
Sep 11, 2009 | 2003 Land Rover Freelander
Low Battery warning on Simon 3 even when I changed it out
temperature affects batteries. if the batteries on the window sensors have been in use for some time it is probably time to change them. Alarm batteries are only expected to last 3 to 5 years with moderate use. If you have close neighbors or live in an apartment complex then false reads could be a factor.
Aug 11, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
Its keeps peeping
Hello twins49
Welcome to Fixya,
You said, your Frigidaire freezer 17 cu. ft. , it keeps buzzing or peeping
The alarm may be malfunctioning or it may be warning you of low temperature.
You can go to any hard ware store and buy a refrigerator thermometer and ask them if it can go into a freezer too!It can, But ask anyway!
If it is cold enough then it is a faulty alarm going off.
Your freezer may be equipped with an alarm.
Here is some information that may help you find it and turn it off if you wish
Temp Alarm (audible only or audible with warning light)
This feature is designed to provide a warning of possible malfunction. If the
temperature of the food rises to a level unsafe for long-term storage, the buzzer will
sound. The red light will also glow on models so equipped. The Temp Alarm feature
operates on household electricity. If power fails, the alarm will not perform. An ON/
OFF switch allows you to deactivate the Temp Alarm when not wanted. The freezer
is shipped with Temp Alarm in the OFF position. After freezer has run approximately
4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm
without the alarm sounding.
Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch.
If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and
seals properly. If you suspect a technical malfunction, call an authorized servicer
immediately.
Let me no what you find.
Huuum
Please remember to leave a rating before you leave
Aug 26, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Acer Aspire 5600 Series 5630-6951 Laptop Logo
214 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
