Question about Hardware & Accessories
I have a Edapt Timer and have lost the instruction manual to set the timer up and going. Do you have a manual for this type of timer, that I can print out and use. If I have a hard copy and the timer does fail again sometime, I'll Know exactly what to do to get it up and running again. Thanks Wayne
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
SOURCE: Need to re-set time on Salter digital timer
If it's the same as ours (clock button top left, clear bottom left):
  1. press and hold clock until the clock starts to flash
  2. set time using h/m/s keys
  3. press clock again
Hope it works
Posted on Nov 01, 2009
SOURCE: Raindrip timer R672C
Problem for Raindrip R673CT Digital Water Timer Raindrip timer R672C I am trying to program the days of the week on this time and cannot do it. Can you help?
Posted on Jun 30, 2010
SOURCE: Noma timer Type EMT757-UL instruction manual How
The backup battery is a rechargeable battery located inside the unit and cannot be changed.
When the battery goes bad, the timer needs to be replaced.
Posted on Nov 03, 2010
  • 70 Answers
SOURCE: I have an automatic pet
there is a 1-800 number that comes with these products for tech support,i am a master electrician and it could be the unit itself and not the timer
Posted on Jun 12, 2011
Purchased EDAPT electronic timer and getting no number at all when pushing buttons ???
The timer may be defective but try Googling (EDAPT)(model)(manual) without parens to get information.
Nov 06, 2016 | Hardware & Accessories
Instructions for timer
Timer is not identified:
Copy following links to identify same-similar timer and download manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Add a comment and describe timer in detail for possible identification
May 09, 2013 | Hardware & Accessories
I lost my instructions onhow to set my lamp intermatic timer to go on and off automatically. How do I get the instructions?
Open following link to identify timer and download possible manual:
Open following link to set analog timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
Add a comment any time for help with specific timer
Take a moment and rate answer for accuracy of information provided:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Hardware & Accessories
Hi I have got an EDAPT timer but no Manual. Not sure how to set it up. Could you please help?
EDAPT timer is 24-hour analog timer with segments located around timer dial and a slide switch located on side. Appears to be mains 240V timer.
http://www.thewarehouse.co.nz/red/catalog/product/Edapt-24-Hour-Timer-Analogue?SKU=767408
Instructions for analog timers appear on following link.
Aug 24, 2011 | Hardware & Accessories
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
Lost instructions on how to set it
If I understand correctly, you have an indoor timer
Your timer is Woods brand. (other brands may program differently)
Your timer has a circular dial on the front. (other types of timers do not have a dial, they has a digital display)
Your timer plugs into the wall -or- it is installed in-wall where a switch goes.
Here is a photo that might help.
To set current time, you rotate dial until is lines up with the triangle shape located on inner dial.
If this is not your type of timer, please answer in return and we'll get your timer going with information that is accurate to your model.
Push pins in and out to control ON OFF functions.
If your timer plugs into the wall, then it will not have the manual override slider switch shown above.
Oct 21, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
I lost instructions on setting the timer.
I Googled in Diehl digital timer and located a website that had the exact timer I have. Included in the list of information was a manual with instructions on setting the timer. I downloaded the instructions and set the timer. Exactly what I needed.
Jan 17, 2010 | Solar Digital Electronic Timer 20/40/60...
Hardware & Accessories Logo
318 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
