Back to:
Tags:
GE GSS20IEP Side by Side Refrigerator
Ge profile side by side model tpx2 4pryfbb serial... (by 2 users)
posted by Wallace1272 on Jun 15, 2008
water collects on bottom of freezer. after 6-8 weeks, it fills the bottom (frozen) but then water starts appearing on floor in front of freezer. water appears to be coming from rear of compartment, as the ice is built up against back wall at bottom (visible only after removing food.
for "water on kitchen floor or on bottom of freezer," troubleshooting section of manual states "drain in bottom of the freezer clogged."
but there is nothing in the manual about the drain, i.e., where it is or how to clean it.
Can you tell me where this drain is?
Comment by Wallace1272, posted on Jun 28, 2008
the problem is that the drain pan was clogged with ice the pan is located behind a plastic cover (one screw in center that is located behind the second shelf from the bottom. you will see that the drain pan full of ice. i left he door open for 20 minutess, then removed the ice. at ge's sugggestion, i used a turkey baster to shot hot water with baking soda down the drain hole. problem solved. one week later, however, freezer is not cold enough (15-20 degrees). fridge side is also not very cold. i don't think these problems are related, and I fear that i need new fridge (current one is 10 years old. i don't want to pay repairman for a new condensor or fan.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jun 24, 2008
Water drips/runs down the rear of the freezer and accumulates on the floor of the freezer as a 'glacier'. I have to remove it about once a week. I thought it was a problem with the icemaker so I disconnected the water line to the refrigerator, but it hasn't changed the problem at all. I'm still trying to figure out where all that water is coming from, since the water line has been disconnected for almost 3 months and I still have to remove a 1/2" to 3/4" thick slab of ice from the bottom of the freezer every week.
Solution #1
posted on Jun 16, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I am having the same problem any suggestions........
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ge profile side by side model tpx2 4pryfbb serial number ls-2858840:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Had power outage , mainboard was making clicking noise ,...
My Admiral Upright Freezer ices up, inside top of door...
freezer not freezing fridge not cooling . ticking sound...
I took the freezer assembly apart (3 screws) and it's a GE...
The drinking water in my refrigerator is barely running....
Loading problems.
Repair Service
Find Refrigerator Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
