Question about Panasonic Lumix DMC-LZ2 Digital Camera
Lumix DMC TZ4 lens cover stuck half open, camera wont switch on tho battery is charged
  • Chris Buckman Nov 07, 2010
    Hi , thanks for reply. The plastic doors in front of the lens are stuck half open, but the lens has retracted inside the camera.
    Regards
    Chris
    • Rank: Guru Cameras, Camcorders & Accessories
    • Rating: 88.03%, 6325 votes
    Hi could you clarify, the plastic doors in front of the lens are stuck half open, but the lens has retracted inside the camera or is the lens in half open position outside of the camera
  • Chris Buckman Nov 08, 2010
    It did'nt help me fix it, so I still have to take it to a repair shop; but I kind of expected that, I was just hoping that there might have been a simple solution!
    Thanks anyway!
  • Panasonic Master
  • 13,433 Answers
Hi could you clarify, the plastic doors in front of the lens are stuck half open, but the lens has retracted inside the camera or is the lens in half open position outside of the camera.
Posted on Nov 07, 2010
  • Ekse Nov 07, 2010
    Sounds like the camera has been dropped or the lens has taken a hit, you can possibly get the doors to close by helping them a bit but its probably not going to solve the problem that the camera doesn't stay powered on.
    Your camera probably flashes on and off, its turning off because its unable to extend the lens out from the camera, the cameras lens will have to be either repaired or replaced entirely.
    A repairer is most likely going to charge you 150+ for this repair.
Telephoto lens stuck
batteries might need charging or try new batteries.
Jul 04, 2014 | Panasonic Pal Version Lumix Dmc-fz47/fz48...
We bought a brand new lumix Dmc TZ4 about a year and a half ago from a reputable seller on Amazon. worked for two days, then without any accidents or incidents, it started saying low battery, even when it...
Hello there.
Since you already changed the battery and still having the same problem, let's try other things.
First, remove the SD card from your camera and try to turn it on. Make sure your battery has a charge.
If that works, then it means the problem is with the SD card.
Also make sure that the battery cover is locked firmly.
Try those first and then update me.
Jul 04, 2011 | Cameras
Hello I have a panasonic DMC-TZ4 digital
You can download and print your camera manual, at no cost, here:
http://www.brynmawr.edu/llc/documents/DMCTZ4.pdf
Apr 22, 2011 | Panasonic DMC-TZ4 Digital Camera
Water damage - screen asking to turn off camera
Hi!
The lens should be taken apart and cleaned. It could be a focus problem. In the worst case it could be a bad lens driver IC. It's a hardware fault not software so you should give it to a repair shop or Panasonic service center.
Sorry for the bad news.
Tom
Oct 09, 2009 | Panasonic DMC-TZ4 Digital Camera
How do I fix a stuck lens stutter (not cover) on a Lumix Camera?
Unfortunately, this is not a problem that I would attempt myself, and unless you are experienced with micro-electronics I would seriously caution you from attempting it yourself.
This is not an old camera model, do you still have a warranty? If so, I suggest bringing it (or sending it) to the nearest Panasonic authorized repair center.
If it is out of warranty, call and find out what Panasonic charges for servicing this camera model. Typically they have a flat rate for servicing each particular model. You might consider picking one up on Ebay if the repair cost is too high. But please know that this is not like old SLR's which could be repaired at home.
Sep 08, 2009 | Panasonic Lumix DMC-LZ2 Digital Camera
Lens cover is stuck half way open on Lumix DMC-TZ3
argh! me, too! i love this camera, but the lens cover is just plain stupid. we used the camera at the beach for a couple days, and i could tell a grain of sand got stuck behind the lens cover. now it is jammed and the camera is totally out of commission. why make a camera built for outdoor conditions, then put a lens cover like that on it!! i can't find a tech who can fix it, either. went to three shops in NYC and all said the cost to deal with it would pretty much buy me a new one... ! :(
Jul 29, 2008 | Cameras
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Lens plastic cover little sheets wont open.
I need to remove front cover and look for an obstruction or possible substance spilled or splashed in camera. N/C for estimates! www.flcamerarepair.com Art Schneider (40 years exp.)
Mar 31, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
932 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
