Question about Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill
Bosch drill has no power i have two batterys they are ok and fully charged as i have tried them on a friends drill but in my drill they are very slow and you can hold the chuck still with your hand any ideas
  • Bosch Master
  • 7,733 Answers
Need an overhaul of the brushes.
Posted on Nov 08, 2010
Bosch PSR 1440 power drill. How do I know when the battery is charged?
Tracey,
There should be a legend on the top of front of your charger that should explain the light sequence for the charging process.
May 15, 2015 | Bosch Drills
PBS 18 li-2 bosch cordless drill lights on but no power.
You are sure the battery is charged OK? Bosch Li-Ion drills have a feature whereby they stop working when the battery is low but not discharged right out. This is to extend the battery life as it does not like being flattened altogether.
This happens quite suddenly, from one press of the trigger to the next. It can make you think the drill is faulty.
If the battery charge is OK, then maybe
- trigger faulty
- motor burnout
- broken contact on battery or in drill battery shoe
Oct 28, 2014 | Drills
I have a makita 8391d cordless drill The problem is that the drill runs incredibly slow even when both batteries are fully charged I have checked the voltage and both batteries are showing the correct...
You have to check the batteries with a new machine. If the new machine works ok then the rotor of the motor of the old machine is broken.
Jan 18, 2014 | Drills
Black and decker drill runs slow
Its much more likely that your batteries are not charging up properly. Ni-CD batteries suffer from 'memory effect' and can appear fully charged when only 70% charged. Also they lose charge when being stored. Do not short them out to discharge them! Wait until the drill complains that they are flat and then recharge them rather than when they first start to slow down. Do not let become completely flat (less than 1 volt).
Mar 03, 2013 | Black & Decker Black and Decker 18V...
My Bosch 24v PSB 24 VE-2 has suddenly stopped working. The battery charges ok but when fitted into the drill , the drill makes a faint whining noise but fails to work. Any ideas ?
Hello
The motor windings in the drill are bad or have a bad connection.You may also try cleaning the battery contact points with a pencil eraser.
Jun 25, 2011 | Bosch Drills
How to fix a dead battery charge for a Bosch drill
If the battery charger is the problem, there is not much you can do apart from checking the power cord and the internal glass fuse. If the cord delivers full power to the curcuit board, then remove the fuse and test it with a multimeter or an ohmmeter. If both is okay, I have no further advise then to replace it. Some times, it could be that the batteries are the ones to blame for a broken charger. Make sure your batteries are ok, so they do not destroy another charger. Check for capasity, excessive temperature when operating or charging, or strange smells indicating burnt components in the battery packs.
Nov 18, 2010 | Bosch 18V Brute Tough Drill with Blue Core...
Battery will "fully" charge and then only run for 20 - 30 minutes of use then be discharged. Have fully discharged and re-charged to no avail. My other battery will run for 2-3 hours of use.
Hi Fred,
I have several 18v tool sets and for the most part I'm quite satisfied with their performance. I currently use Bosch and Ryobi.
When used with the drill, a battery can last me the whole day. On the other hand, the sawzall will eat them up pretty quick.
The thing I've found common to all brands is that it is absolutely crucial to make sure the batteries are fully charged before they get used for the first time. That first full charge seems to set the bar for subsequent charges for the rest of the batteries life.
I too, have tried the discharge/recharge thing. No help. I can only suggest a new battery and letting get all it can take from the charger the first time out of the box.
Since I've been doing that, I rarely even think to bring my charger to job sites, there's that much of a difference in performance.
Hope this helps you out.
Best regards,
Mike
Mar 31, 2010 | Bosch 18V Brute Tough Drill with Blue Core...
Craftsman power drill - batteries wont recharge. When I insert dead batteries into the charger The green light ''Fully charged'' comes on and stays on. The batteries do not charge as when they are inserted...
the battery's are most likely dead, (like the real dead) after many uses of rechargeable battery's they slow stop holding charge at all, make sure when you get a new rechargeable battery you fully charge it once and fully discharge it once this will increase batterys life time
Sep 27, 2009 | Drills
Bosch 33614-2g 14.4v Brute Tough 1/2" Cordless Drill Logo
277 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
