Question about Asrock 775VM800 Motherboard
My machine has this problem. every time i switch it on it says mac address are invalid in both cmos and flash. what do i do?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
Configured the BIOS settings yet? Make sure your set the RAM to run as Supports DDR400/333/266 non-ECC, un-buffered memory Max. capacity of system memory: 2GB
the RAM you installed and to match the CPU bus. And there's probably several other settings that need to be tweaked as well. For example, if you're not running RAID, disable it.
If the problems continue, you may wanna try updating the BIOS. Actually, I just had a look at the ASRock site & here's what the latest BIOS fixes: "Modify MAC address function algorithm"
http://www.asrock.com/mb/download.asp?Model=K7NF2-RAID&s=462
Posted on Nov 07, 2010
Error mac address are invalid in both cmos and flash
does your mac have a battery back up battery like pc's do.
the battery in the mac may not have enough power to keep the cmos information together, replace the battery and you should be okay
Sep 23, 2014 | Asrock Computers & Internet
Mac adress are invalid in both CMOS and Flash
i have your problem.but when i use asrock mac tool it said "Not supported"!.infact it not supported mac address on stick on main board!but my hope was the mac 6 digit that newer tool write.then i change my mac by mac changer from windows and then set that mac to bois and flash by asrock mac tool.every thing get ok:)
Jun 19, 2014 | Asrock Computers & Internet
My asrock p4vm890 is has invalid mac address for both cmos and bios
The MAC is the unique identifier for the onboard LAN chip - if it's invalid then the chip has been fried - disable it from the BIOS and install a new PCI LAN card.
Mar 27, 2011 | Asrock P4VM890 Motherboard
Modelo: ALiveNF6P-VSTA Problema: MAC address are invalid in both CMOS and Flash!
The onboard LAN chip has been fried. Disable it from the BIOS and install a separate PCI LAN card.
Feb 13, 2011 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
"MAC address are invalid in
Find the highest version bios flash file 1.50 and do it from DOS from a Boot Floppy or CD
http://www.asrock.com/mb/download.asp?Model=775VM800&o=BIOS
Feb 05, 2011 | Asrock 775VM800 Motherboard
Mac address is invalid in both cmos and flash
The MAC address is burned in the Ethernet card chip, you won't see it in the Bios or if you do you can't change it. MAC address changer are tweaks to not being tracked.
The solution to know if the card is blown is to do a complete reinstall of your operating system and if then you can't connect whit it, it is indeed dead. Then Disable it in the Bios and had a PCI one to replace it.
Those kind of problem whit network cards happens a lot when you get a power outage, if you had one in the last couple of days your problem is most likely it.
May 27, 2009 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Mac address wrong in both cmos and flash press f1 to continue
MAC address is not held in CMOS. Please describe the symptoms - what hapens when you switch on, what does message say exactly?
Nov 22, 2008 | Computers & Internet
'mac address are invalid in both cmos and flash'
K, i hv a solution for u, first u need to download afudos utility from http://www.ami.com/support/downloadagreement.cfm?DLFile=support/downloads/amiflash.zip&InpDrvID=90. And then go to DOS mode, n type command like,
D:\...........\afudos /mxxxxxxxxxxxx
There is /m is the command n 12 times x is ur mac ID. N u can find ur MAC on some were on ur MB.
I think this will fix ur problem.
May 16, 2008 | Asrock 775VM800 Motherboard
Samsung vm8000 laptop
run cmos setup and try to configured in factory default settings...
Mar 23, 2008 | Computers & Internet
Asrock 775VM800 Motherboard Logo
185 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
