Question about Lexmark X5470 All-In-One InkJet Printer
Lemark 5400 can't faxor rec fax give phon lone error message
Havse dsl modom can't fax or rec fax give phone line error message
  • PREMIE Jun 16, 2008
    no phone and fax possible
    install en uninstall cd
  • 48 Answers
If u have DSL modem ..u need to have a splitter for the fone line.....and then....the connections need to be right...
Phone line to splitter -splitter to Fax mech(Line Jack)...
Problem Receiving--
Make sure ur answering Mech rings are set more than the fax mech...i.e (if ur answering mech is set to 3 then fax mech should be set to 4)....
If u r using DRPD(distingtive ring pattern i.e If u have one line and two numbers.....) then set double ring for fax and single for Phone or answering mech....or vice versa...
Posted on Jun 19, 2008
Comm error message
PROBABLY BAD PHONE LINE, CAN TRY SOME OF THE FOLLOWING
SLOW DOWN THE RX TO 1700
TURN OFF ECM
INSTALL DSL FILTER EVEN IF ITS NOT A DSL LINE
MAKE SURE THE PHONE COPANY KNOWS ITS A FAX LINE
IF ITS VOIP IT MAY NEVER WORK WELL
RESEAT ALL CONNECTORS IN FAX 3900
TRY SETTING TO MMR
MAY ALSO BE PROBLEM WITH THE SENDING FAX MACHINEOR, THERE PHONE LINE
Jul 11, 2013 | Konica Minolta Minolta FAX3900 Digital...
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Fax rec 2-3 pgs OK, then disconnects and gives Comm Error
These errors mean that the communications have failed, and can mean that the receiver at the other end has terminated the call prematurely.
If the problem occurs with the same destination, then the receiver fax may be the problem.
If the error persists try disabling ECM
Feb 04, 2010 | HP LaserJet 3055 All-In-One Printer
I Have HPofficejet 5510.some pages fax while some do not. I get communication error message. Please help
Sounds like some bad copper wire somewhere:
Try replacing the telephone wire between the fax machine and the wall.
If you have dsl, make sure the fax phone wire is plugged into a filter.
Try setting the fax machine to transmitreceive at a slower speed.
This could indicate a problem with your phone wires. Is there static on your phone line?
Maybe give your telephone company a call and have them check the line(s).
Hope this helps!
Aug 10, 2009 | Office Equipment & Supplies
I can't send a fax on my lexmark 5400. It gets to
Do you have or does the receiving party have a DIGITAL phone line?
ALL fax machines are ANALOG devices.
Jun 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Help with outgoing faxes
Unplug the power cord for 30 seconds. Are you trying to fax on a DSL or any other kind of digital phone line?
Jul 03, 2008 | Brother IntelliFAX 5750e Laser Fax
Cannot recieve faxes
you need to watch during ringing period need to click ok or press what ever message says.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
175 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
