Question about Refrigerators
Zanussi electolux zenb 2625 si fridge freezer fridge not getting cold can hear the pump running
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
SOURCE: zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Posted on Mar 28, 2009
MATRIX_MMX
  • 209 Answers
SOURCE: zanussi fridge freezer
dear plapy
This to me sounds as if either your gas is not circulating through the refrigeration system, or you have a problem with thermostat. If you have recently physically moved the fridge and then powered the appliance up on the mains without letting the gas settle, then you could have damaged the fridge. And there is not really a lot you can do about this, unless you want to call out a refrigeration engineer to re-gas your fridge and assess the circulation of the pumped cold air flow.
Other problems aside of gas and thermostat could be associated with the pump (if your model has one fitted), and with this in mind, i have a good mind to have a look at the SIOS (spares, Information, Ordering, System) disc for zanussi vendored models and then get back to you once i have a further solution for you. However, I will need your make and model of zanussi fridge, so if you have this to hand it will be most appreciated. In the sad event that you dont have the paperwork/ manual for the fridge, then you can find the manufacturers model details on the rear of the fridge. however, when you move the fridge, you will need to let it stand again before powering up the unit after repair, and this should be done for a period of no less than 24 hrs, and no less than 28hrs if your appliance is a fridge freezer combi.
So once again, when i recieve further information regarding your make and model of refrigerator, then i will be able to fully investigate this matter for you, and try to come up with your most appropriate solution..
In the mean time, i bid you take care, and hope to hear from you soon
Yours sincerely
oz
Posted on Apr 11, 2008
woodchuck789
  • 4059 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
SOURCE: fridge heller model fdh21has motor running but does not get cold
i have just purchased a float with a kitchen in it the fridge is a heller bar fridge not sure on model and for the 2nd use it is running but not getting cold or icing up the freezer what do i do to fix it it wouldnt be 10 weeks old
Posted on Dec 20, 2009
I have a zanussi frost free fridge freezer and the fridge is not cold but the freezers fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Zanussi Refrigerators
Freezer working perfectly but Fridge section not cold Model Refeerences ZD-28/11 155/2T
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 21, 2011 | Zanussi Refrigerators
Defrosted freezer and turned back on. freezer seems to work but not fridge. back wall of fridge feels warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 22, 2011 | Zanussi Refrigerators
Freezer ok but fridge does not get cold
heatman101
Feb 27, 2011 | Zanussi ZEBF250W Bottom Freezer...
Fridge will not go cold
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Jan 27, 2011 | Zanussi ZI918 / 12K Bottom Freezer...
I have zanussi zx99/5w and fridge not working and freezer cold but not freezing
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Oct 17, 2010 | Zanussi ZX99 / 5 Bottom Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
dear plapy
Yours sincerely
oz
Apr 11, 2008 | Refrigerators
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Fridge not working
Sounds like the refrigerant has leaked out of the system.
Jul 28, 2006 | Zanussi ZSS7 / 5W Compact Refrigerator
Refrigerators Logo
312 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
