I need a copy of win xp to reboot my laptop. how can i get one for free. i also have a cracked monitor and am trying to use an external monitor.
    Guru:
  • 1,833 Answers
You don't need a copy to install winxp in your laptop. You need the key of your genuin winxp. If you had a genuin MS winxp OS earlier, find the key. Write it down in a paper. Now use any winxp cd to install and type your key (genuin winxp). You are just fine. This is as good as your previous genuin winxp.
If you need it only to boot then create a recovery disk from from your friend's winxp machine. Use it for booting.
Posted on Nov 07, 2010
When Win XP restarts display is black.
Have you considered a Exorcist? Have you cleaned the fan, vents, heatsink recently? Take a look at this it may help in troubleshooting: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Apr 28, 2013 | Acer Aspire 1640Z Notebook
I dropped my dell notebook on the floor. The screen is 80% frozen however when I turn it off and reboot I can tell from the little corner I can see that the computer function but the screen stays stuck....
Try connecting an external monitor to your laptop via the 15 pin VGA connector located on the left side of the laptop.If the laptop display is normal on the external monitor then most likely your LCD (liquid crystal display) panel is damaged and needs to be replaced. The spider web effect is due to cracked display panel.
Sep 12, 2011 | Dell Inspiron 1525 Notebook
I want to boot from a external hd with win xp in a hp pavilion 1129la
FlashBoot is the easiest product available to build an external boot disk. They provide a free demo version that can test before you pay for the program. FlashBoot can load many different operating systems but the program can also use FreeDOS, which has no additional licensing fees. If you have limited computer experience, this is the way to go.
May 23, 2011 | Computers & Internet
When i turn on my dell vostro a860 the screen is black.When I plug in external monitor shows pictures on both (monitor and laptop).When I disconnect external monitor the laptop works fine.The trouble is...
Windows Vista® 1 Right-click an open area of the desktop. 2 Click Personalize. The Personalize appearance and sounds window appears. 3 Click Display Settings. 4 Select the external LCD monitor in the drop-down menu.Monitors and Displays 51 5 In the Display Settings window, move the Resolution slider bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK. Windows® XP 1 Right-click an open area of the desktop. 2 Click Properties. The Display Properties window appears. 3 Select the Settings tab. 4 Select the external LCD monitor in the Display drop-down menu. 5 Under the Screen resolution section, move the slide bar to the left or right to select a screen resolution that matches the native resolution of the external LCD monitor. 6 Click OK.
Jan 02, 2011 | Computers & Internet
Laptop to external monitor problems
Right click anywhere on Desktop> Properties>Settings> Try to lower Screen resolution.
Mar 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Boot problem on inspiron 1150
Try connecting it to an external monitor.
When you do, as soon as you press the power button to turn on the laptop, close the laptop lid - as this forces the laptop to display on an external monitor.
If this works, then it means the laptop screen is bad.
If it doesn't, the most likely cause would be that the laptop video card went bad.
For a while, some older Dell laptops with high-end nVidia graphics cards tended to die suddenly.
Mar 27, 2017 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
'ntlr missing' after restart.
I have had this problem in the past and it was a virus. I had to reformat the hard driver then renstall the windows.
Feb 07, 2009 | Gateway MX3225 Notebook
I was trying to save a file from laptop to my USB external HD, Due to big files it went to a delay write failure, my external HD suddenly stopped working. Whenever I plug in to any computer it just detect...
Hello. It sounds like your external hard drive has crashed, or is getting ready to crash. If you can back up your data, you should do it now. If not, you should get your drive to a professional as soon as possible.
I'll monitor this thread. If you have any more questions, please feel free to ask.
Jason
Jan 26, 2009 | Computers & Internet
Installing win xp from external hard drive
Umm...is your laptop crashed??? Usually ntlldr issues ****. try to delete the former installation so a new ntldr file can be installed so as to not conflict with the damaged ntldr file that is on the pc blocking the install. It sounds like your setup is ok...at the very least get another xp cd to make sure the disk is not damaged that you are loading windows from.
Aug 01, 2008 | Computers & Internet
Cannot install win xp
Hi Phine_24,
I think you've problem with Harddisk.Try to find spare one and install again it should work. Very strange is that if you remove your hardisk out and test externally it should sometime work fine but sometime fail.I think it's a starting sector or some check up that windows or hardware need and it couldn't access it.
goodluck,takecare.
May 04, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
