Question about Sony CDX-646 10-Disc CD Changer
Remove CD Magazine - No power to unit!
I have removed my CD Changer from my car but the CD magazine is still in the unit.
Does anyone know how I can remove it without powering the CD Changer???
I connected this changer with new Bus cables to my CDX-GT710 but it will not eject the magazine or operate.
  • 8 more comments
  • cmssr Jun 15, 2008
    The changer is connected to the head unit,
    CDX-GT710 but it will not eject or operate.
    The changer is already connected to the power
    source, head unit CDX-GT710 that is installed and operating in the vehicle.
    I re-checked all the connections.They are intact. Is there a re-set switch on the changer also?
    The power source is connected,cables are firmly intact but it will not eject.Is there a re-set switch on the changer also?
    Where is the changer ground wire located?
    Is there a seperate ground connection from the changer to the Head unit?I have not used the changer in about two years.
    The changer is connected to the head unit,CDX-GT710 with the RCA and BUS cables
    No, it does not power on.
    The changer is connected to the head unit with the RCA and BUS Cables but will not power on.
  • cmssr Jun 16, 2008
    These are a new set of cables that I recently bought from crutchfield.
    President:
  • 2,712 Answers
Looks like an issue with the BUS cables. Try a new set and see if that helps
Posted on Jun 16, 2008
  • Swilin Sampson
    Swilin Sampson Jun 16, 2008
    It could also be an issue with the power circuitry, as you say that you have not used the changer in over 2 years..I recommend calling Sony support..
  • Swilin Sampson
    Have you tried connecting to an external power source like a car battery? If that still does not power up the charger, then it is defective and you will need to get it serviced.
    If you enter your Zip in the box marked "Repair Service" at the right of this dialogue box, you will be able to find a service center in your area.
    Unfortunately, there is no other fix for this, if the cables are all OK.
  • 4,472 Answers
You will need to power the unit to eject the cartridge you only need a 12v source, any car battery etc. Then you just do it like you always do it. It is correct that it is not operating without power.
Wish there was an easier way for you, but hooking it up to power is not to difficult.
Good luck and if you need any other info on the device let me know,
Lee
Posted on Jun 15, 2008
  • 8 more comments
  • Lee A.
    Lee A. Jun 15, 2008
    So If i gather the information correctly,
    You have it hooked up to a 12v power source?
    You can eject the changer right on the changer itself. You slide the panel open and hit the eject button. Only thing that is required is power.
    Hope that will help you if not let me know,
    Lee
  • Lee A.
    Lee A. Jun 15, 2008
    Also do you have the power connection for the changer grounded properly?
    Lee
  • Lee A.
    Lee A. Jun 15, 2008
    Does the CD changer unit power on at all? If it is still not working
    the unit is most likely defective. for about a 100$ you can get a new
    sony changer. I know this is not the solution you are looking for, but
    it seems there are not any options left beyond that.
    Thanks and keep me informed,
    Lee
  • Lee A.
    Lee A. Jun 15, 2008
    No there is no reset switch.
  • Lee A.
    Lee A. Jun 15, 2008
    Does the unit power on?
  • Lee A.
    Lee A. Jun 15, 2008
    Where do you hook up the power to from the cd changer?
  • Lee A.
    Lee A. Jun 15, 2008
    Also if it is 2 years old and hasn't been used that could be even more reason for the problems.
    Let me know where the power is going to from the changer and hopefully we'll get this solved.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 16, 2008
    my best solution r going down
  • Lee A.
    Lee A. Jun 18, 2008
    Hook the unit up directly to a 12v source and then test to see if it powers on.
    If you found any of these solutions helpful please accept and rate accordingly.
    Thank you,
    Lee
  • Lee A.
    Lee A. Jun 21, 2008
    Let me know how it is going.
    Thanks,
    Lee
    Master:
  • 638 Answers
You have to connect the cd changer to the cd mazine without that you cannot remove as it may damage your unit.so try any shortcut to remove.go for this long and safe solution. this will definately 100% solve your problem.
  • 7 more comments
  • hemant somaiya
    hemant somaiya Jun 15, 2008
    rate this solution as fixya and encourage us to solve more and more problems as yours. thank u for using fixya. wish u success.
  • hemant somaiya
    need any further assistance reply me. so i can help u more on this problem. got the idea then rate so i can continue towards other problems.
  • hemant somaiya
    please check whether some connections got loosened while removing ,because of that it is not working.reply me urgent for further guidence
  • hemant somaiya
    accepted the solution then rate it as fixya.for further help reply.
  • hemant somaiya
    you can also call normal electric engineer to checkthe connection.if u are not able to.
  • hemant somaiya
    there is no such reset facility in the unit, but u can remove all the connections throuly but carefully and reconnectit after few minites .then see it may start working.
  • hemant somaiya
    reply me what happened iam waiting
  • hemant somaiya
    actually there is no reset button visible but my rigrous search in the manual of your product says find it and try
    there is a reset button inside door or on changer some where that you press and hold and reset system. If not then unplug from power for atleast 15min. Re-enstall
    if this does not helps then trythis
    it should need to power it take to local car shop then send 12 v to oit to get cds out ok thx for using fix ya
  • hemant somaiya
    waiting for your reply.
  • 1,879 Answers
U need to re-connect it in order to remove the magazine
  • monk3ybidzness
    monk3ybidzness Jun 15, 2008
    i mean - back into the car
I need a 6 disc magazine for my Pioneer PD M530 Multi-disc player. Can anyone tell the model number of the magazine so I can locate one for sale
I may have one for sale. Please let me know by visiting my website, audioserviceclinic.com, and contact me there.Thank you.
Dec 24, 2014 | Pioneer Car Audio & Video
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
6 CD Changer Jammed (Audi A4)
You may have to remove the unit and disassemble it to remove the CD that evidently is jammed inside. If your unit has a removable magazine that holds the CDs, the magazine probably is stuck.
Oct 22, 2017 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Manual removal of cd magazine
Seems to me an error of the installers, just go back and ask them to remove the magazine properly.
Aug 08, 2008 | Alpine CHA-1214 12-Disc CD Changer
I fixed my similar problem by applying 12v to the unit according to the pinout found here:
http://users.ntplx.net/~andrew/sony/unilink/
(note that -12v goes to the connector barrel)
Apr 26, 2008 | Sony CDX-656 10-Disc CD Changer
Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Jul 29, 2007 | Bose Lifestyle 30 System
Inoperable CD changer
Hi the alpine/merc/bmw cd changer all seam to suffer with the same problem, they say no disc, or no mag try firmly hitting the mag with the handle of a screw driver. the loadinga arm, tends to get stuck. you could try using some grease on the arms, and levers, white spray gease works best. but dont forget to cover the laser beforehand, you dont want grease on it :) Mark www.carradiospares.co.uk
Mar 27, 2007 | USA Spec MERC99 6-Disc CD Changer
Sony CDX-646 10-Disc CD Changer Logo
781 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
