Question about Maytag Atlantis MAV6451 Top Load Washer
Machine won't spin dry completly. - Maytag Atlantis MAV6451 Top Load Washer
  • 6,993 Answers
Go to the below link.
http://www.fixya.com/support/r6546726-reasons_washing_machine_drain_or_spin
Good luck.
Posted on Nov 07, 2010
How to more dry after completed washing
A washing machine does not really dry clothes. All it does is that it helps remove most but not all water from the clothes by spinning the clothes at a very high speed and the water comes out because of centrifugal force.
To further dry the clothes, you need to buy a clothes dryer. This machine has a heater inside that actually dries the clothes while keep it spinning at a slow speed.
Usually the company that made your washing machine will also have a dryer in the product portfolio.
Hope that helps
Feb 22, 2015 | Washing Machines
Will not spin the clothes dry it's seem it is not balanced ?
You may have One wet heavy item (one sweatshirt or one bath towel) that is not evenly dispersed within the wash tub, and this will prevent the machine from reaching and completing the spin cycle.
Jul 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Water will not drain out of the washing machine and won't complete cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Kenmore Washing Machines
I have a Whirlpool Ultimate Care II washer Model#LSB6300LW0 that would not completely dry the clothes on the spin cycle. I'm not sure if the unit was spinning fast enough. I replaced the lid switch and...
It sounds like your Drain pump has either become clogged, or has burned out.
  1. First, disconnect the power to the machine.
  2. The drain pump is located at the bottom of the machine. You will have to remove the panel to access the drain pump, or you can access the drain pump from the bottom of the machine after you have removed the water from inside the machine.
  3. The drain pump has 2 hoses connected to it, and a wiring harness.
  4. Disconnect the hoses and wiring harness and remove the drain pump.
  5. Check the impeller inside the drain pump for coins, socks, etc. and clean it out if you can. Make sure it turns with ease, and isn't worn out, or rocking back in forth. If it is worn out, replace the drain pump.
  6. If after clearing the drain pump and reassembling, and the machine still fails to drain, replace the drain pump.
Jun 07, 2011 | Whirlpool Washing Machines
Maytag washing machine does not spin completely dry model # LA846 have repaced water pump and main drive belt but still does not spin completely dry
First be sure that your drain hose is not kinked.If your hose is not kinked then I would suggest that you buy the roller kit for the motor plate and replace the rollers.
Apr 29, 2011 | Maytag Washing Machines
My machine will not spin dry and empty the water after a wash, the lights will just blink and the machine will stop.
My machine won't spin or drain and just goes on and on for hours not taking notice of the cycle I put it on, can anyone help?
Jan 03, 2011 | Whirlpool AWG5122 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
Maytag Atlantis MAV6451 Top Load Washer Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
