Question about HTC EVO 4G Smartphone
How to fix the cause code 98 error class 3 - HTC EVO 4G Smartphone
2 Suggested Answers
  • 285 Answers
SOURCE: sms error cause code:255 error class:3 on adroid eris phone when send text to a certain person
u need to format u phone ur phone completely
Posted on Mar 11, 2012
How to remove from the error 5201
What Type of Printer is it? Each Company has their Own Trouble Codes...
Cannon for Example"
Problems with Error 5201
Cause: 5201 errors usually are caused by misplacement or broken system registry
structure.
Note: This is also a critical sign of an unstable system that is usually caused by improper
maintenance of the computer
Solution: RegCure is a Microsoft Certified tool that is tested to repair issues with code 5201 errors.
Download & Fix with Regcure Repair Tool Free!Windows 98/SE/ME/XP/Vista Compatible
Regcure Additional Features:
Repair ALL detected Registry Errors instantly!
Optimize PC's performance up to 300% Faster!
Prevents Freezing & Crashes - Completely!
Increase Window's Boot & Programs Speed!
Advanced Windows configuration settings!
Error Code 5201 Problems
JavaScript / Scripting Errors
Internet Explorer / Active X Errors
EXE / DLL / OCX Errors
Virtually all Windows related Errors!
How To Use:
Step 1: Download & install RegCure Repair Tool for FREE!
Step 2: Scan your computer
Step 3: Click the 'Fix Errors' button & your DONE!
Apr 12, 2013 | Office Equipment & Supplies
Et1505an code reader comes up with link error every time i try to scan my 04 f-150 is it the scanner or my truck if it is my truck what is the cause. How would I fix it ?
The only way to find out if it is the code reader or the truck is to plug in another code reader or scan tool and see if it gives you the same results (try this first).
NOTE: Generic OBD code readers will operate ONLY on the Class 2 data link. A true scan tool will operate on BOTH the Class 2 and the UART lines. Accessing the onboard computer system with a scan tool may give you a fault code that indicates that the Class 2 circuits may be malfunctioning.
To diagnose onboard computer network communications malfunctions, the proper equipment that can communicate with the ENTIRE network must be used. Please note that generic OBD code readers cannot perform this function.
Apr 28, 2012 | 2004 Ford F150
How to fixed drive error windows 98 when i start
please tell us what your computer specification to understand the problem ( note : win 98 make more problem with new computers and the compatible pc's with win 98 is pentium 3 computers.
best regards
Apr 21, 2011 | Microsoft Windows 98 for PC
P0218/P0742/P1811/&U1301 Please can someone help me. i have these diagnostic codes for my 2004 chevy venture van LS. i am needing to know what they are and how i can fix them. I would greatly...
CODE PO218 - TRANSMISSION FLUID OVER TEMPERATURE.TRANSMISSION FLUID IS LOW OR CONTAMINATED BURNT OR DIRTY.CHECK TRANSMISSION COOLER LINES FOR DAMAGE OR RESTRICTION. CODE PO742 - TORQUE CONVERTER CLUTCH CIRCUIT STUCK ON. CODE P1811 - MAXIMUM ADAPTIVE LONG TERM SHIFT. CODE U1301 - CLASS 2 CIRCUIT SHORT TO BATTERY.POSSIBLE CAUSE CLASS 2 SERIAL DATA LINE WAS IN A HIGH STATE FOR 3 SECONDS DUE TO A SHORT TO VREF OR SYSTEM POWER. ONE OR MORE MODULES ON CLASS 2 LINE HAS AN SHORT TO POWER.LOOKING AT ONE OF THE CODES.TRANSMISSION GETTING TOO HOT.DUE TO OVERHEATING ENGINE OR YOU ARE TOWING OR PULLING MORE WEIGHT THAN YOUR VECHICLE CAN HANDLE.CAUSING ENGINE AND TRANSMISSION TO OVERHEAT.
Feb 06, 2011 | Chevrolet Venture Cars & Trucks
Hi, I have a emachines by acer laptop and it does show me that windows 7 have an error code 31. I have tried already to fix it by doing the system restore, I dowloaded the drivers that have being deleted...
  1. Restart your computer if you haven't done so already.
    There is always the remote possibility that the Code 31 error you're seeing was caused by some temporary issue with Device Manager. If so, a simple reboot might fix the Code 31.
  2. Did you install a device or make a change in Device Manager just before the Code 31 error appeared? If so, it's very possible that the change you made caused the Code 31 error.
    Undo the change if you can, restart your PC, and then check again for the Code 31 error.
    Depending on the changes you made, some solutions might include:
  3. Delete the UpperFilters and LowerFilters registry values. A common cause of Code 31 errors is the corruption of two registry values in the DVD/CD-ROM Drive Class registry key.
    Note: Deleting similar values in the Windows Registry could also be the solution to a Code 31 error that appears on a device other than a DVD or CD drive. The UpperFilters/LowerFilters tutorial linked above will show you exactly what you need to do.
  4. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 31 error is a likely fix for this problem.
  5. Replace the hardware. As a last resort, you might need to replace the hardware that has the Code 31 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you're convinced that hardware isn't the cause of this particular Code 31 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those before you try replacing the hardware, but you may have to give them a shot if you're out of other options.
Please let me know if you've fixed a Code 31 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 31 error could apply to any hardware device in Device Manager but most Code 31 errors appear on optical drives like CD and DVD drives.
Any of Microsoft's operating systems could experience a Code 31 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Jun 18, 2010 | Computers & Internet
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
How do I force XP to accept a Windows 98 driver?
Try this one:
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R46297&formatcnt=1&libid=0&fileid=54266
May 19, 2008 | Dell Inspiron 7000/7500
HTC EVO 4G Smartphone Logo
619 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
