Question about Acer Aspire One PC Notebook
Check cable connection... - Acer Aspire One PC Notebook
  • 757 Answers
Checking the cable connection involves inspecting the integrity of the cable ends. On a LAN connection for example, both ends of the cable when properly connected should not be loose and an orange or amber light should be visible in the transparent plastic cable connector.
Posted on Nov 07, 2010
What do if my lenovop pc showing only not connection ?
Check if your LAN-cable is plugged into computer and in the other end of cable to wall-outlet/adsl-modem/some router /switch
If the cable is connected is the indicator light on both ends.
Thunder and lightning could have a electrical surge in the internet grid?
Mar 27, 2012 | Lenovo Computers & Internet
When i click the scan button it states check connection connect interface cable
It sounds like you have a bad connection. This could either be the cable itself, the plug on the cable, or you may have the cable connected wrong. Check to make sure that both plugs are securely in place.
Dec 22, 2010 | Brother 6-In-1 Printer/Fax/Copy/Scanner
I have a rca modem. And I pay my internet company on time. But on the modem the cable link blinks slowly and and I am not getting no internet connection. So I want to know if the cables are plugged wrong...
Of course the first thing to do is to check the connection of your cable all the way to the wall. Did you disconnect anything?
It is usually best to unplug the cable modem from anything connected to it and to check after you disconnect if from the power outlet and the cable. First connect the cable back and then the power and check what is going on there. If you are connected to Cable TV then of course check your TV set if you are getting anything.
you can try to log into the modem itself: For a RCA cable modem, you may need to navigate to http://192.168.100.1/moreInfo.html to view the diagnostics.
Sep 26, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Connection for cable
A snowy picture is usually an indication of a bad ground. Check the cables at both ends to be sure that the braid(shield) is still intact and connected to the F-connector. Also, check the connections on the exterior of the house. You can also call the cable company and have them check the connections at the poles.
Dan
May 10, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
Mp3 player won't charge on my pc... how do i fix that?
Check the Following Instructions:
1. Check USB cable properly connected to the USB port.
2. If cable not connected properly or cable break, It should be not connected or not charge.
3. Change the another USB Cable, If problem presit, check ur PC USB Port.
Apr 11, 2010 | Samsung YP-K5 MP3 Player
TV is fuzzy and not showing a clear picture
  1. If your set is connected to a cable TV box via coax cable check the connection on the cable box (both Input and out to TV connections) tighten if necessary.
  2. If your using a cable splitter to split the cable to multiple TVs check those connections also.
  3. If this fails to correct the problem you may have a bad cable which your cable provider should replace at no charge to you.
Dec 17, 2009 | Dell Televison & Video
I put photo paper in the feeder but it won't feed.
check if cable between PC and printer is connected if not connect printer to PC cable........if cable is connected check if printer driver is connected if printer is not connected install drivers for printer into your computer.....if driver is installed do a clean up for your printer - check for any jammed paper, check rubber roller is grippable....etc..
Nov 05, 2009 | HP Photosmart C7280 Printer
I have a G+ Router. After connecting all cables,
sounds like you do not have any physical connection. this is your layer 1 application. Check your cable to ensure that the mod ends are good. Check to see if you have a straight thru cable connected now. If so try a cross over cable.
Jun 06, 2009 | NetGear WGR614 Wireless Router
When I select print all that happene is - sending data.
hi im josh in cebu phils. may i help you? friend try to check this: The first item to check is whether your printer is connected correctly to your computer. Check the connecting cable to make sure that the connections are tight. You also should unplug each end of the cable to ensure that none of the connecting wires are bent, making a bad connection. You might also want to change the printer cable. Cables can get old, and the wires inside can break; try a new cable and see whether this change fixes the problem.
good luck hope i helped you.
Mar 04, 2009 | Computers & Internet
My computer won't recognize my new 80GB Seagate IDE hard drive so I need instructions of how to install it properly or some instructions after the install
Go to the bios setup during boot & check whether this drive is shown there. If not, Check whether you have connected the drive rightly. i.e. the connections for IDE cable & power cable are securely connected.
Also, check whether you have setup the master/slave/cable select jumpers rightly..
Set the jumpers on your hard drive for cable select. If you have another drive also connected via same cable, then set the jumpers on that drive for cable select mode.
Alternatively, set one of the hard drives as master & other one as slave.
Also make sure that you have connected the cable in the right direction. Long leg of cable towards the motherboard side & short leg towards the hard drives side.
Hope this helps you friend..
Aug 06, 2008 | Computers & Internet
Acer Aspire One  PC Notebook Logo
98 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
