Question about Kitchen Ranges
My washer is leaking from somewhere..whenever i wash clothes i see water underneath..
    Genius:
  • 1,672 Answers
Open the back panel of ur washer, check the leaks, from ur WATER inlet or ur DRAiN valve got holes!
Posted on Nov 07, 2010
Washer beeps as if unbalanced when in rince cycle and water is leaking a bit from somewhere, clothes are still damp. fisher and paykel
if it's leaking, take it somewhere to get checked, water and electronics don't end up mixing in a cheap way! the leak could be the pump or main seal. the unbalanced thing can be due to spring failure.
Aug 15, 2013 | Fisher and Paykel GWL11 Top Load Washer
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Water leak ge clothes washer
Replace the anti-siphon valve
Anti-siphon valves prevent water from siphoning back into the water supply. Also known as vacuum breakers, anti-siphon valves are used on washing machines, faucets, toilets, sprinklers and other water sources. A leak on an anti-siphon valve can cause deterioration of the appliance's external components and damage the flooring material underneath the washing machine. Therefore, a leaking anti-siphon valve should be attended to as soon as possible.
Jun 08, 2012 | GE WBSR3140DW Top Load Washer
Standing waterin the door opening seal after each load.
Sometimes small pieces of clothing get into drain system and plug off draing. Check before pump for clog.
Oct 02, 2009 | LG WM-2277HW Front Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Kitchen Ranges Logo
42 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
