Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
My coffee machine will not pick up the milk from the jug. I have replaced the o ring as that is normally the cause. It only gives off steam
    Scholar:
  • 36 Answers
It is always difficult to diagnose without seeing the machine but it sounds to me that it is a seal somewhere further that may have gone or the pipe inside may have a small hole drawing air in. It could also be the pump not drawing the milk through etc etc...
Can you tell me where you are? I am an agent for DeLonghi based in Glasgow/UK and would be able to fix this easily and quickly for you if you could get the machine to my workshop. Please get in touch if you would require further assistance at domesticespresso@live.com
All the best
David
Domestic Espresso
Posted on Nov 07, 2010
Hi there, Are you able to tell me pls why my milk frother doesnt really froth and sounds really squeeky and gives a flat coffee pls?? Ive done the cleaning scale thing.
have you checked steam without milk jug to see if steam is coming out.
If steamer has an add on plastic part that could be blocked
Feb 26, 2017 | Coffee Makers & Espresso Machines
Delonghi EN720 milk won't flow properly.
replace o ring ,,, descale ,,, disasemble ,, clean ..
Dec 14, 2013 | DeLonghi Coffee Makers & Espresso Machines
Hi, I am having trouble getting the milk to froth without bubbling. Ihave cleaned it really well and hoping you have the solution. Cheers Denis Stevenson
sounds like the milk jug has not been inserted correctly
give it a wobble whilst using
check the o ring on machine wher the jug plugs in as there could be dried milk around it letting air into the system or faulty o ring
Jun 05, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
176 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
