Question about Amana Dryers
Amana dryer led20aw need wiring layout - Amana Dryers
  • 525 Answers
Below is a link that will provide you with a wiring manual.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Hope this helps!
Dave E. (Illeagle)
Posted on Jun 15, 2008
LED20AW Heating element
No Jim, that amount of lint is normal in all of those dryers. You should clean it out annually to prevent fires. The front panel under the door is all that you should have to take off to get to the heater coil and to clean it out.
Jan 20, 2014 | Amana Dryers
How to change an amana dryer belt on a model # led20aw
Here is the diagram for the Amana dryer belt routing.
Here is a video to show you how to open the dryer.
Oct 02, 2011 | Amana Dryers
I have an model led20aw it is not heating. Heating element is good. What else could be the problem
First make sure you have 240 Volts going into the dryer. If you do you would need to chase all the wiring for a loose connection (usually burnt). First look at the timer, then there are thermostats near the element to be checked and there is a switch mounted on the outside of the motor; it has two "bigger" wires connected to it. Sometimes the connection burns loose at that point.
May 20, 2011 | Amana Dryers
Amana dryer model no led20aw will not start
When the dryer won't heat or will not start it is the thermostat/thermal fuse that is bad, you can test it with a voltmeter before replacing. This fuse is located inside the rear panel and it cannot be reset.
Hope this will help....
Dec 31, 2010 | Amana DLE330RAW Electric Dryer
Amana Dryer Model# LED20AW S/N#. S 9707026456 The only way it runs if you hold the srat button down.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 12, 2010 | Dryers
Dryer has stopped spinning
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Oct 31, 2009 | Amana DLE330RAW Electric Dryer
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
How to install drum belt in Amana Model LED20AW. This model does not have front or back panels to remove. Fabio
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Getting to heating element/thermal fuse for amana model LED 20AW
I just replaced mine by taking the bottom off, but in hindsight I think I should have been able to do it by just removing the lower front panel. With long arms, you should be able to reach back and loosen the two bolts holding it in place. Good luck!
Apr 05, 2009 | Amana Dryers
Dryers Logo
363 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
