Haier front loader 6kg washing machine comes up with error 5 and you cant turn it off or start it again,you have to turn power off
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
davess26
  • 7 Answers
SOURCE: error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Posted on Oct 26, 2008
  • 3 Answers
SOURCE: error code de on samsung front loader J845
The door lock is the problem... try to push the door harder... or change the door lock! It is usually done in 5 minutes.. .... if it is only 5 months... you have a warrenty!
Posted on Jan 26, 2009
SOURCE: error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Posted on Feb 06, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
I have an haier front loader washing machine hwm80-1403d and it is flashing an error3. What can I do have never used it.
Hi!
On Haier washers error 3 means "Detected washer temperature sensor error"
Check connections to washer temperature sensor.
Check temperature sensor.
Jan 07, 2017 | Haier Washing Machines
LG 6kg front loader keeps beeping on pressing the power button
Try unplugging it for 5 minutes and see if it resets, if not you may have a door closed sensor issue.
Aug 18, 2016 | LG Washing Machines
My Haier 6kg AA washing machine keeps coming up with error code 1 what's the problem?
Hi Carys from retired Englishman in SW France,
For Haier error code 1 states 'door is not properly shut 20 seconds after program has started'
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor becoming apparent requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 14, 2011 | Haier Washing Machines
Haier 6kg top loader HWMP60TLF Water dripping from top of rubber hose where it connects to bottom of drum. The rubber hose diameter is at 40mm at the drum end and the hose twists through 90 deg and reduces...
have u tryed putting a hose clamp around the 40 mm end?or has it got a small hole in it? please reply 4 more help. i have worked on these machines b4. please turn off power b4 you work on it, don"t want any accidents.
May 08, 2010 | Washing Machines
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
Displaying error 1
ERR1: The front door is not properly shut. You should make sure the door is firmly shut, then start the cycle again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 10, 2009 | Washing Machines
Err 7
Err7 is a motor error.Check out the following Haier washer manual link (page number 17).
for washer manual click here
The only solution suggested is to replace the motor.
Jan 08, 2009 | Haier Washing Machines
Error code 7
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
