SOURCE: printer does not make black
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
SOURCE: Kodak EasyShare 5100 won't print
Hi FixYa team, my Kodak printer's "Check color ink" red light was flashing so I just put in a new color ink cartridge (even though I am only printing black and white). I restarted the machine to try and print some address labels and it acts like it is printing but the paper comes out blank yet I can print pictures. I tried to print and email and it won't do that either.
Thanks.
SOURCE: Ink level will not reset when cartridge is replaced
If you take the cartridge to walgreens, etc... they can clear the chip. There is none for home use
give them a call !
SOURCE: Kodak 5300 shows
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Testimonial: "I will give it a shot when I get home..Thanks.."
SOURCE: printer will not print in black
Try reinstalling the software. If you are using the disc it came with make sure you check web installation. Do not plug in printer until told to do so.
