Question about Cameras
How do you set the time on the Pelco KBD300a?
Where can I find an owners' manual and/or installation/set-up guide for a Pelco Model No. CCC1370H-2
[PDF]Pelco CCC1370H-2 CCC1370H-2X and MCC1370H ...
pdfstream.manualsonline.com/.../550025fc-8c14-4275-8558-aa0699ab3e5...
The CCC1370H-2, CCC1370H-2X, and MCC1370H-2 digital cameras are ... model. Eclipser Level Controls (NTSC/EIA Models Only) a. Threshold - Sets the ...
Sep 18, 2015 | Pelco Home Security
How do I reset KBD300 pleco keyboard
To initialize the keyboard, wait five seconds after powering-up the CM6700, enter the number for the
monitor you are viewing (1-4), and press MON. The LED display shows the number entered.
NOTE: You must re-initialize whenever power is cycled.
Source: http://www.jmacsupply.com/v/vspfiles/files/PMFiles/Pelco/Instructions/KBD300A-InstallationManual.pdf
Jan 15, 2015 | Pelco Kbd300a Pushbutton Control Keypad W/...
Need to increase the hard drive to at least 6TB
Nor am I.
A 6Tb hard drive cost around $850.
You need to check if the Pelco can support a hard drive as large as this and it will need the operating system installed on this hard drive,
The Pelco may have a slot to install a second hard drive.
Oct 19, 2012 | Pelco DX4516DVD-250 16-Channel Digital...
I have 6 pelco make 5104 dvr connected to a
If all of the 6 DVRs are on the same location (on the same network), and you want to remotely connect (VPN) to that location, you can Endura Enable the DVRs and then VPN to the Primary DVR. (Note that you need to be Endura Certified to use the Endura Enabled feature).
If they're all geographically distributed, you can only VPN into a single unite at a time..
Jul 15, 2010 | Pelco Video Recorder
My pelco DVXe dvr display is at minimum not 32 bit cant see pics
boot into bios and set your display for vga mode. At least that worked for me
Apr 09, 2009 | Pelco Home Security
Power went out now my pelco kbd300 isnt working
If no power, it must one resistor of power interface circuit burnt. you need to send it for repair.
if it can be powered up, just can't cotrol. you can try to press the key of F5(AUX OFF), and powered it and hold "AUX OFF" for more 3 seconds and release. this mothod is used for calibrate the joystick.
Mar 12, 2009 | Pelco KBD9000 Keyboard
I'm looking to config a Pelco DX2000 Dvr with A cross-over cable
You can connect it to your PC directly with a cross-over net cable, and you also connect it to your LAN with straight net cable. Type The default address: 192.168.2.108:8004 in your IE after you set your pc address in the same geteway, you will see the user and PW requirement screen. if you can't get this screen,try to reset DVR to default setting. see Page#100 of its manual.
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
Cameras Logo
315 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
