Question about LG L1915S 19" LCD Monitor
Dear experts, I have an LG Flatron L1915S that was working properly in my old computer. I am trying to connect it to my laptop but i get a black screen. The power supply indicator is on and the cable that connects it wiyh my laptop ( also an LG R 510) seems to work properly. In my laptop I have Intel Graphics Media accelerator driver. I have tried several times with no results. Could toy please help me. Thanks in advance for your help.
SOURCE: monitor LG FLATRON E700SH
do any one have the moniter sittungs of LG E700SH
Posted on Jan 28, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: cable advice...
There's an adapter cable required to go from the Mac's external monitor connector to a standard VGA plug. You can see what it looks like here at the Apple Store site. Once you have the adapter you can use a plain old monitor cable with VGA plugs at both ends to connect your Flatron.
Posted on Mar 31, 2009
  • 415 Answers
SOURCE: screen dead
since it's only 3weeks old as long as you have the receipt take it back .
Mark
Posted on Apr 18, 2009
SOURCE: I have lg flatron l1730s
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display.
Posted on Nov 11, 2010
budmrtn
  • 11361 Answers
SOURCE: MY 19"LG FLATRON L1915S FLASHES
Lok for bad caps with domed tops as shown in my pictures here:
http://s807.photobucket.com/albums/yy352/budm/LG%201915S/
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 05, 2011
LG flatron l1915s monitor, green led flashing only when coming out of standby resulting in no picture
Check the electrolytic capacitors inside in the power supply board portion. replace all busted ones.
Jan 10, 2014 | LG L1915S 19" LCD Monitor
Monitor will not go on or off, no power at all. checked all connections. I have a lg flatron 4 ms 1400-1, purchased in 2006.
Sounds like the power circuit on the monitor is bad, this is not user replaceable.
You can try letting the monitor sit for a few hours and trying again, as sometimes these monitor can overheat but this is a less likely reason for your issue.
Mar 15, 2011 | LG L1915S 19" LCD Monitor
HI I have used LG Flatron L1915S computer monitor. When I plug it into my laptop, it blinks showing the laptop desktop for less than a second then goes black. Other monitors works fine when I plug them...
There is often a function monitor key on the laptop, located near the F7 key area, the icon looks like a monitor on|off and is typically in blue. this key is to be used in combination with the Fn key to enable, disable the external monitor or enable both monitors or just the laptop. Press the key combination until your laptop panel lights up while the monitor is plugged in. Now check your extenal monitor refresh rate and resolution slider settings by right clicking on your desktop go to properties / video settings. (please note monitor settings are under advanced). You should see two monitors in there now. use "identify" button so you know which one to work with. on the external monitor settings, decrease (slide left the slider all the way). If you can set the monitor refresh to 60Htz. Lastly take a flashlight and check if you can see a shadow of your screen on the external monitor, if you can that means the backlight is not working and likely needs the inverter replaced. Hope that helps ! Cheers
Aug 30, 2010 | LG L1915S 19" LCD Monitor
I turn on my FLATRON L.1730 SF but after a few seconds it says POWER SAVING MODE and the monitor remains black.
Try selecting a different input from the monitor's menu, perhaps it is set for digital input while you feed it analog VGA signal, or vice versa.
Jan 28, 2010 | LG L1915S 19" LCD Monitor
When I booth it says 'power save' and turn black
This is not a problem with the monitor, but with the VGA card. Replace it and check.
Sep 02, 2009 | LG L1915S 19" LCD Monitor
After starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Aug 28, 2009 | LG L1915S 19" LCD Monitor
Shade difference in lg lcd diaplay
Based on your description, it appears that the monitor is faulty. Since it is only a week old, you should have no problem exchanging it.
Aug 22, 2009 | LG L1915S 19" LCD Monitor
Powersaving mode
I think your signal Cable is not connected properly.please check. Is your computer booting. Can you see HDD acivity LED blinking in your CPU?
This should solve your problem.Best of Luck.Please rank me appropriately. If you want any clarification, Please get back to me
Jul 03, 2009 | LG L1915S 19" LCD Monitor
Cable advice...
Mar 31, 2009 | LG L1915S 19" LCD Monitor
LG L1915S 19" LCD Monitor Logo
82 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
