Question about Car Audio & Video
Location of Relay for an amp turn on on a 02 town and coutry
  • 417 Answers
its not a relay, its a small amp, our caravan has one. you have to find the amp relay wire coming out of the stock harness , use a haynes or chilton manual for the color and connect that wire with switched power wire from the ignition. using two amps in series may be too much preamp voltage for your new setup so you may have to splice before the stock amp under the dash, or manually wire around the stock amp, the stock amp is fused with the cig lighter and isnt listed, check that fuse too.
good luck
.jm
Posted on Nov 07, 2010
  • Jude Meredith
    Jude Meredith Nov 07, 2010
    hi ,
    depending on the setup you may have to splice AFTER the stock amp. keep the stock amp hooked up to the fronts and disconnect the doors and backs and run that through your new setup maybe. the stock door and rear speakers should be able to handle up to 100 watts any more then that leave the stock amp the way it is and splice in before the amp so your head unit is running to the stock amp and your new amp. something like that..
    jm
How do to replace a flasher in a 2001 pt cruiser
Signal Flasher Location - PT Cruiser Forum
www.ptcruiserlinks.com > ... > Tech & Performance Forum
Nov 10, 2010 - 10 posts - ‎4 authors
I have installed LED turn signal lamps in my 09 PT. ... Seems the flasher relay location for 2001-2005 is different of the 2006-2010 PTs. Turn signals not working
Dec 27, 2011
Replace Multifunction Switch w/fog lamps
Jun 27, 2007
PT turn signals (or lack of)
Mar 17, 2005
Turn Signals Not Working
Jun 20, 2004
More results from www.ptcruiserlinks.com
how to replace the turn signal flasher on a 02 ... - YouTube
? 5:35
https://www.youtube.com/watch?v=ikJHh7OLcXg
Aug 16, 2009 - Uploaded by bguess
HOW TO REPLACE THE TURN SIGNAL FLASHER ON A 02 .....Replacing flasher/turn signal relay on a ...
FLASHER RELAY - 2001 Chrysler PT Cruiser - RepairPal
repairpal.com > ... > Chrysler > PT Cruiser > 2001 Chrysler PT Cruiser
Feb 9, 2011 - FLASHER RELAY on 2001 Chrysler PT Cruiser. WHERE ARE THE TURN AND HASZAD RELAYS LOCATED. by moposse in Des Moines, ...
Nov 26, 2015 | Chrysler 2001 PT Cruiser Limited
Tourqe specs for transmission pan bolts 2005 town and country
i need torque spec on 2005 chrysler town and coutry van for transmission bolts are 10 m
Dec 31, 2012 | 1997 Chrysler Town & Country
Location of mazda premacy 02 petrol fuel filter
What causes the pump not to run when turning on the ignition & click sound of relay then no spark on a Mazda premacy?
Nov 16, 2012 | Mazda MPV Cars & Trucks
I had to chang the engine computer on my 02 town and country. Do I have to take it to chrysler to get it reprogramed for my van?
the town and country has a PCM ( power control module, located in front to the battery ) and a FCM ( front control module located on the front of the relay center next to the battery ) if either module is replaced they need to be programed with a DRBIII, so you will need to see your dealer.
Sep 09, 2011 | 2002 Chrysler Town & Country
Fuel pump not getting power
It will be in your engine compartment fuse panel the letter H 30 Amp is the fuel pump relay
Jul 29, 2009 | 1988 Lincoln Town Car
Where is the factory amp located in the 2001 Chrysler Town and country?
The amp relay is in the Relay/Fuse box located under the hood. The amp relay is the one labeled NBS which stands for Name Brand Speakers. If you are trying to install an after market radio in a 2001 Chrysler Town and Country, you may notice that no sound comes from the speakers. This is because the single wire that is connected to the factory radio sends a signal to the Bus which tells the relay to turn on - powering the factory amp.
I bypass this by running a wire from the red Acc power wire on the radio to the relay. Connect the wire to pin number 87 on the relay. When standing in front of and facing the van, pin number 87 is the pin, on the NBS relay, which is closest to you and furtherst right.
Are you looking to replace the amplifier? or bypass the speaker wires??
Usually factory amplifiers in vans are under the P/S Front seat. However they can be up under the dash as well (P/S).
If you're looking for it because it is not turning on - check the relay (as above).
Thanks for using FixYa - a FixYa rating is appreciated!
Jan 31, 2009 | 2001 Chrysler Town & Country
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
