Question about NEC Computers & Internet
I have this motherboards how many hard drive Can I conect? I have one of 80gigas Can I conect another one?? thanks
    Genius:
  • 1,672 Answers
Yes! U can connect another one as SLAVE!
Make sure u put the jumper in the SLAVE pins!
Posted on Nov 07, 2010
Can my hdd samsung 1tb model hd103SI work with 775dual-880Pro motherboard? I conect but Its not deteted!
That is an Asrock board and Yes, any standard hard drive will work with it. The reasons for your problem in descending liklihood:
>Your connection is incorrect or a bad cable.
>If you have an operating system, there is a corruption/problem with it.
>The hard drive has failed
>Drive is not activated; enter Disk Manager and activate it.
May 18, 2014 | Asrock Computers & Internet
Keeps saying reboot and insert correct media
Hi
your hard drive conection with your motherboard is loose. you hav to go to service station to fix it
thanks
Jan 04, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
My computer is not recognize my external hard drive
sometimes wires get loose and do not make good conection make sure wires are making good contact to your hard drive. and to motherboard . first. and as always unplug pc first.
Jan 01, 2011 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
Blue screen keeps coming when going in to windows\r\nand rebooting, updated the bios, and tried other memory in it but still blue screen
this is becuse of the error in the hard disk remove the error hard disk and conect as slave to a working computer make the working harddisk as first boot my clicking boot in bios right click my computer and click manage then click disk management you will see the two drive partition now scan the faulty hard drive or format the drive and install the windows
Nov 17, 2010 | ASUS A7V600-X Motherboard
Can I use my current w d. external hard drive with my laptop computer as well as my desk top.
you can only use it as an external on the laptop if you use it as an external you can use on the desktop just plugging the usb also if your motherboard has sata conection you could install it into your desk top.
Oct 06, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Replace Hard Drive Motherboard??? Where to order parts???
Purchase a new enclosure, any enclosure depending on the hdd conection in the my book. take the drive out and then put it in the new case. hopefully that shoud work.
Nov 25, 2009 | Western Digital My Book Essential Edition...
Hard drive connection to motherboard
You can find standards from any hardware related book or website. (ehteshamhusain@gmail.com)
Apr 13, 2009 | Computers & Internet
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Installing Hard Drive on Dell 8300
I am assuming that you are installing the Western Digital WD2500SB as a second Hard Disk in your Dell 8300. If it is connected along the same flat IDE cable as you old/original HD (Primary Master), you need to move the jumper in the WD for it to be as the Primary Slave. Instructions and illustrations are normally printed on the sticker atop the HD. If you are connecting it to the 2nd (Secondary) IDE, pls verify that it is not in conflict to any other device attached to it such as your CD/DVD. At any time, only 1 can be a master and the second device be the slave.
To verify that indeed your wiring/jumper and settings are correct, you can go to BIOS/CMOS setup immediately after powerup and determine if your PC has auto detected the new HD as well as the old/original HD & CD/DVD.
If for wahtever reason, the PC will not auto detect the new (Western Digital WD2500SB) HD and since it is new then, it should still be covered by the warranty and you can ask for a replacement.
If on the other handyou would want it to the the primary master and you would like to run your PC's OS on that new HD, you would need a CD installer/recovery to re-install the operating system.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
