Question about Microsoft Office Professional 2007 Full Version for PC
I am on Ms Windows XP Professional with Ms Word 2007. An error message says " there is not enough memory or disk space to run word". Expect a solution on line free of charge.
    President:
  • 2,340 Answers
1. Resolution from Microsoft.
or
Most probably your users' profile is corrupt!!
Try this,
1. Created a new user profile
2. Use windows cleanup to delete old files.
3. Restart PC and use new account.
4. Works...?? when you open Winword?
5. Then use your newly created account.
** Don't forget to backup your necessary data first
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Posted on Nov 07, 2010
    Master:
  • 969 Answers
Go 2 "My Computer". Right click on "C" drive. The window will indicate blue space 4 used space on drive & pink 4 empty space. Click on disc clean up if required.
When i try to open word it comes up with a message that says "there is not enough memory or disk space to run word" what should i do??
try to delete (uninstall ) some software like wallpaper changer etc or increase ram thanks dont forget to give vote bye
Aug 13, 2011 | Microsoft Office Professional 2007 Full...
When trying to install Fix-It Utilities 10, I get the error message 1935. "An error occurred during the installation of assembly" 'Microsoft VC90.CRT,type"win32" and it won't...
Sorry Martin. We don't have a lot of choices here! After re-starting your computer, check you have enough hard-drive space if in doubt, Clear all junk in memory, close all programs running, go 'off-line' (it may require you to go back on line later to Register) Then check disk is clean and unscratched, and try to install again. If it fails you will have to return to your supplier for a replacement. good luck!
Aug 02, 2011 | Avanquest Fix-It Utilities 10...
"There is not enough memory
Hello okhandiar
Your HDD is full . Delete all unnecessary files . You can go to My computer , right click on C , select properties \ disk clean up .
Best regards ,
fanaudi .
Mar 24, 2011 | Microsoft Office Professional 2007 Full...
I have xp i have 512 MB RAM and P3 processer but i cant not install ms office 2007
In order to install any software, it is imperative to ensure that the computer in question meets or exceeds the minimum requirements.
Foremost, Microsoft Office Basic/Standard/Home & Student/Professional/Small Business/Professional Plus/Enterprise 2007 require a CD-ROM or DVD drive. Microsoft Office Ultimate 2007 requires a DVD drive.
Microsoft Office Basic/Standard/Home & Student/Professional/Small Business/Professional Plus/Enterprise/Ultimate 2007 requires a system that has at least 500 MHz (since a Pentium III can range in speed from 450 MHz to 1.4GHz, it seems likely that you've met this specification); & at least 256 MB of RAM (your system's 512 MB meets this & is the minimum amount recommended for Outlook Instant Search).
However, you did not make mention of which service pack (1, 2, or 3) that is installed on your version of MS Windows XP (MS Office Basic/Standard/Home & Student/Professional/Small Business/Professional Plus/Enterprise/Ultimate 2007 requires at least SP2); nor did you mention how much free disk space is on your system. MS Office Basic/Standard/Home & Student 2007 requires at least 1.5 GB (MS Office Professional/Small Business/Professional Plus/Enterprise 2007 requires at least 2 GB of free disk space & MS Office Ultimate 2007 requires at least 3 GB of free disk space. Also, MS Office Basic/Standard/Home & Student/Professional/Small Business/Professional Plus/Enterprise 2007 requires an Internet browser comparable to at least Internet Explorer 6 (IE6).
By the way, OneNote Instant Search & OneNote Audio Search require a CPU of at least 2 GHz & at least 1 GB of RAM. 1 GB of RAM is also the minimum requirement for grammar & contextual spelling in Word. Business Contact Manager requires a CPU of at least 1 GHz & at least 512 MB of RAM. Since you did not mention your exact iteration of MS Win XP (Home/Professional/Professional 64-Bit), it is important to note that "Send to OneNote 2007" print driver, Internet Fax, & Groove Folder Synchronization are not available on 64-bit operating systems.
Furthermore, I do not find it reasonable to quote any more specifications such as those for MS Office Accounting products unless found necessary, besides such specs are readily available at http://office.microsoft.com/en-us/products/2007-microsoft-office-release-system-requirements-HA010166865.aspx?CTT=1.
It is entirely possible that the cause of installation failure could be a faulty optical disk drive (CD/DVD/etc.) an invalid product key or perhaps an operating system (OS) which the installation deems to not be genuine.
Sep 25, 2010 | Microsoft Computers & Internet
Error installing MS Office pro 2007 with BCM
Uninstall from control panel the following:
Microsoft SQL Server native client
Microsoft SQL Server Setup Support files
Microsoft SQL Server VSS writer
Move directory C:\Program Files\Microsoft SQL Server\MSSQL.1 to another location for possible use. Delete everything under Microsoft SQL Server in c:\Program Files
Reinstall
Jan 10, 2010 | Microsoft Office Professional 2007 Full...
MS Office 2007 Professional won't install on my Laptop with XP
yor ms office 2007 cd or dump is corrupt pls try another one
Jun 24, 2009 | Microsoft Office Publisher 2007 for PC
Ms office won't open gives there is not enough memory disk space full message but memory no where near full
Depending on how much disk space you have left onyour hard drive, Microsoft Home and Student requires at least 1.5GB offree space. I've posted the minimum system requirements below, you willneed these to run Office Home and Student 2007.
Minimum Requirements: (View on Microsoft Website)
  • 500mhz Processor
  • 256 Memory (RAM)
  • 1.5GB of Free Space (Hard Drive)
  • CD/DVD Drive
  • Display: 1024x768 or higher resolution monitor
  • Operating System: Microsoft Windows XP with Service Pack (SP) 2, Windows Server 2003 with SP1, or later operating system
Mar 15, 2009 | Microsoft Office Professional 2007 Full...
Ms office home and student 2007 not enough memory or disc space
--Please make sure your system has minimum following configuration
CPU 700 Mhz
Ram 512 MB
HDD 4 GB free
--Use good Antivirus to scan system
--Repair OS before reparing Office
Thanks
Zulfikar Ali
Jan 23, 2009 | Microsoft Office Professional 2007 Full...
Not enough space or memory to run Word 12.0
Could you please let me know what operating system present on your PC?
Antivirus/Firewall and other spyware/adware utilities present on your PC.
I would suggest you to make a complete uninstall of MS OFFICE (including all components of Ms Office 2003 & Ms Office 2007 if present anyone ) then go for fresh installation of MS Office 2007.
Let me know if the problem still persists. Dont vote till you get the solution for this problem.
Thanks
Scott
Nov 12, 2008 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
189 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
