Question about Western Digital My Book Home Edition 500 GB USB Hard Drive
My hard drive starts but the file won't open. I reprogrammed it but the outcome is the same. If you open the file it freezes the screen till I can close the file. Is there a way to fix it? Please and Thank you..
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Posted on Nov 07, 2010
My computer accesses the file on the external hard drive, starts to download the information, then my computer freezes. The only way to get out is to power down, holding the computer button down till it...
maybe the file is corrupt or has a virus. Do full virus scan on freshly rebooted computer. try starting the PC in safe mode (F8 when booting) and open the file. do other files of the same type open up ok?
Sep 27, 2017 | Cavalry Storage Cavalry 500GB 3.5 7200RPM...
Tip
10 reasons why PCs crash-You must know tip 4
4 Hard disk drives
After a few weeks, the information on a hard disk drive starts to become piecemeal or fragmented. It is a good idea to defragment the hard disk every week or so, to prevent the disk from causing a screen freeze. Go to
* Start-Programs-Accessories-System Tools-Disk Defragmenter
This will start the procedure. You will be unable to write data to the hard drive (to save it) while the disk is defragmenting, so it is a good idea to schedule the procedure for a period of inactivity using the Task Scheduler.
The Task Scheduler should be one of the small icons on the bottom right of the Windows opening page (the desktop).
Some lockups and screen freezes caused by hard disk problems can be solved by reducing the read-ahead optimisation. This can be adjusted by going to
* Start-Settings-Control Panel-System Icon-Performance-File System-Hard Disk.
Hard disks will slow down and crash if they are too full. Do some housekeeping on your hard drive every few months and free some space on it. Open the Windows folder on the C drive and find the Temporary Internet Files folder. Deleting the contents (not the folder) can free a lot of space.
Empty the Recycle Bin every week to free more space. Hard disk drives should be scanned every week for errors or bad sectors. Go to
* Start-Programs-Accessories-System Tools-ScanDisk
Otherwise assign the Task Scheduler to perform this operation at night when the computer is not in use.
on Mar 04, 2010 | Computers & Internet
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
The screen freezes
Possible that PC is hanging up as there is fault on the OS . So try and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
If there is no response then the OS must be reinstalled.
Jul 14, 2011 | Computers & Internet
Computer turns on but will not load windows. Freezes after gateway comes on. Plus cannot start in safemode
Enter the BIOS and ensure that the Hard drive is indeed being seen by the computer.
Open up the chassis side panel and ensure that all conections are making contact.
damnor01
Apr 14, 2011 | Gateway 3250S PC Desktop
I cannot open files and folders as it takes too long to open and it also freezes my PC...please help as I cannot locate some of my files too...need your help.
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive))
defragment your hard drive will speed up your computer
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
hope this helps
Jan 26, 2011 | Iomega (33652) 250 GB IDE Hard Drive
Everytime my laptop opens its saying a SMART failure was detected in ur hard disk drive,click F1 to continue...do i really have to change my hdd or it can be fix..but if i check in device manager it says...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive or
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
good luck with this
Sep 15, 2010 | Hitachi Computers & Internet
WHEN I OPEN ANY FILE FROM THE WD PASSPORT OR TRY TO INSTALL A VIDEO OR PICTURE IT FREEZES THE MY LAPTOP FREEZES THEN I HAVE TO SHUT EVERYTHING DOWN
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 11, 2010 | Western Digital My Passport Essential SE...
My computer is not reading the hard drive. I get the following message: "The file or directory is corrupted and unreadable." I've never unplugged it without going through Safely Remove Hardware. I have...
If your External HD is not regerstering it might have errors in it, I had this problem with my Simple Tech 500gb pininfarina and heres the steps that finnaly after days of trying to figure out it worked:
(Before starting make sure to disable your screen saver)
1. Restart the computer without the device plugged in to start fresh
2. Wait till it loads up and NO OTHER PROGRAM IS RUNNING
3. Plug the usb into the device then the computer usb port
4. Plug in the power to the device and wait till all the lights are cycling if they do
5. Now open the command prompt
6. Type in “Chkdsk /f N:” or whatever letter your device is in and let it run if its not moving don’t do anything till it is complete.
Mine was fixed after letting it do it for about an hour of just sitting there it had a lot of errors in the HD
Hope it helps
Jun 19, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Possible Corrupted Hard Drive
is it a lappy or desktop? if its a desktop, you can make your drive a slave in order to recover those files that you want. same goes if its a lappy. however, it would give you a hard time becasue you have to take out the HD fro the lappy unlike the Desktop cpu.
seems like your froze to a point it cant pass over the startup windows loading. it may be that some window files were tampered by an illegal operation by some of your programs.
reformat will do the trick. recover your files by using another cpu of a friend and after that, reformat that drive.
May 31, 2008 | Computers & Internet
Western Digital My Book Home Edition 500 GB USB Hard Drive Logo
48 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
