Question about Canon PC-940 Black and White Copier
Error code E2 with a rattling sound when turned on canon PC940 copier--started when it was opened and then closed.
  • 14 Answers
SOURCE: Canon PC940 Problem
You could have a broken exposure lamp. Does the scan bar light up when you make a copy? If not that is the problem. You might also ck the contacts on the machine where they touch the toner cartridge. The toner cartridge opens a shutter to the drum when you slid it into the machine and that may be broken.
Posted on Feb 13, 2008
MediaMan85
  • 163 Answers
SOURCE: canon cp94o display error E0
Exactly when did the E0 come up? that is the error for the fuser not heating up and shouldn't have anything to do with black copies. What is the status now and please add more information.
Posted on Mar 18, 2008
Cogz
  • 1326 Answers
SOURCE: canon copier PC720
A E2 code deals with the scanner. The optics of the copier. Has itbeen moved resently? Your lens may be off it's track. Turn the copier off and remove the copy board glass and the Black Box and try to move the lens and the scanning mirrors to see if they can move smoothly. If not you have found your cause of the noise and what needs to be repaired. It may not be worth getting fixed. That is older model, it's up to you..
Posted on Jul 27, 2008
SOURCE: canon printer E2
printer in side paper or not feedind paper or paper sensor damaged
Posted on Oct 12, 2008
fotobean
  • 103 Answers
SOURCE: On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Posted on Dec 11, 2008
E2 alternating with 10 - error message. If I turn it off, it makes a loud rattling sound noise when turned on
if the paperjam was removed incorrectly, it could have tampered with the timing of the gears or maybe even broke a gear
Jul 03, 2016 | Office Equipment & Supplies
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Start button for canon pc940
I also am having this problem...but the system tray disapears almost like someone took some scissors and cut it out..and all my icons slide under the startbutton. but whatever programs that are unminamized i can still use..but thats all
Mar 19, 2014 | Canon Pc940 Alog Copier 13cpm 0008a040
Trying to find a manual for a canon pc940
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC940-User-Guide-TkRFd01URT.html
Jan 01, 2011 | Office Equipment & Supplies
Canon pc940 error code e261
try turning the machine off and then on...you either had a power surge and it freaked out your machine or the fuser is shot...
Dec 17, 2009 | Canon PC-940 Black and White Copier
Reset E0 code on canon Pc940
Fuser error you need to replace fuser assy.
Oct 21, 2009 | Canon Office Equipment & Supplies
My canon M 160 jammed, I pulled paper thru, now it won't print
E2 is "NO PAPER" error but in most case it's showing when the paper feed is in incorrect position.Check it movement correctly and check for any objects drop in printer.
Jun 14, 2009 | Canon PIXMA MP160 All-In-One Printer
Canon pc940 won't turn on
power fuse blown on power supply board ,replace it.
Dec 10, 2008 | Canon PC-940 Black and White Copier
Canon PC940 Problem
Feb 11, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
205 people viewed this question
old marine
old marine
