My laptop's light goes dim when on battery - Computers & Internet
    Master:
  • 969 Answers
UR battery might not B fully charged or capable of holding a full charge. Click on the battery indicator on the task bar 2 get battery status.
Posted on Nov 07, 2010
Battery volts goes up and down and dims the lights
go get ur battery check at a parts house like napa or autozone that what it sounds like to me
Jan 25, 2013 | 1999 Chevrolet Silverado 1500
Toshiba laptop display goes dim
If you are operating on battery this is a power saving mode. Go into setting and see what the power settings are. Try running on charger and see if this still happens.
Oct 20, 2017 | Computers & Internet
If the battery is draining when the car is off most of he time it is from eather a light on the you may not be able to see like a glove box light or a radio staying on
to fix this u will need a test light (borrow one or buy one there cheap if u dont have one)
disconnect the positive battery cable attach one end of test light to the positive battery post attach other end of test light to the disconnected battery cable if the light real bright start pulling fuses until the light goes out or goes real dim (the dim light is the draw from computer,radio,etc so small of draw wont hurt battery) once you pull the fuse that makes the light go dim or out check that circuit for short circuits
if when you put test light on light not on or real dim before u pull fuses you more than likely have a weak battery that wont hold a charge
Feb 11, 2011 | 1996 Jeep Grand Cherokee
Laptop will not charge. when I plug my laptop in to the power cord no lights come on except for the light on the power supply cord goes dim and blinks. anyways help?? thanks, Krystina
Not knowing the age of your unit I can only say that the charger or the battery may be at fault. It is highly unlikely that it is your laptop. Thanks, Dana
Jan 06, 2010 | Gateway M-6843 Notebook
Screen goes dim while in use
If you're using the battery, change the power saving settings.
May 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dead laptop
take out the battery of the laptop and try starting it on the AC adapter,
if it doesn't work, if your friend has the sam ac adapter try starting your system with a different Ac adapter, if nothing of this works
call your laptops technical support
Further Queries are welcome
If you think my solution was helpfull please do rate me
Feb 21, 2009 | Computers & Internet
Lights dim and then brighten
This is your Alternator. Check the Battery Cables for Tightness in Addition.
Jan 12, 2009 | 1997 Nissan Pickup
Acer4520
This is normal for any notebook - it reduces power consumption to make battery last longer.
You can turn up brightness manually if you want to (usually an FN+F? key combination).
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Computers & Internet Logo
Alun Cox
k24674
