Question about Dryers
Maytag Electric dryer
Model Pyet244ayw Does not drye, apparently no heat
  • 1 more comment
  • hhawley11 Jan 31, 2009
    How do you access the heating element and overtemp thermostat?
  • Anonymous May 01, 2009
    Does not dry consistently on automatic dry, clothes are still very damp when it stops. Does better on timed dry, But still does not seem to dry very well.
  • Anonymous Mar 15, 2014
    DRYER RUNS BUT WON'T HEAT UP
  • 525 Answers
Below is a link to assist you in identifying, ordering parts, and disassembly procedures diagrams.
Before you do that though, you may have a tripped circut breaker or a blown fuse, so the first thing to do is to verify that you have 240 volts to the dryer. Verifying this could save you a lot of time and money. A $10.00 multimeter. available at most hardware stores. will allow to verify your voltage and help to diagnose all the electrical parts in the dryer
http://www.repairclinic.com/0100_18.asp
If this helps, please rate my assistance to you, or post me back if I can be of more help.
Dave E. (Illeagle)
Posted on Jun 15, 2008
Whamaytag performa electric dryer model number pyet244ayw does not spinm?
Drum belt failure or worn drum belt has fallen off the motor pulley or tension idler has failed or reached its limit because the belt is too loose
Sep 03, 2012 | Dryers
Need to convert electrical Maytag Performa Dryer (Model:PYET244AYW) to propane gas system. It can be converted?
No that can not be done fairly inexpensivly...it could be converted but would actually cost more to purchase all needed parts that it would be to buy a brand new gas dryer
Oct 16, 2011 | Maytag PYE2300AY Electric Dryer
How i can replace duck kit
Lowes or Home Depot should carry that.
Jul 06, 2010 | Maytag PYE2300AY Electric Dryer
My 8yr old Magtag PYET244AYW dryer is getting worse...
check the air flow at the exhaust,
you should have a good and steady flow while the dryer is running.
sometimes cloggs happen in the middle of the exhaust line
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer won't start
thermal fuse is the white platic fuse mounted to the exhaust about 6'' from the blower
easy to get to with a snub 1/4 '' drive
Sep 30, 2009 | Maytag Dryers
Maytag Performa Electric Dryer Won't Start
check the blower wheel, sounds to me like it is loose on the blower motor, common on these dryers. One sure sign would be a warped filter and a rusted top. The blower aint putting out enough and the dryer is over heating .
/uploadswith image
Mar 08, 2009 | Maytag PYE2300AY Electric Dryer
Maytag PYET244AYW Electric dryer
could be an overheated motor, but always clean venting and make sure it is under 20' with fewer than 4 elbows. mat'l should be metal. filter housing sometimes get clogged also, look inside and remove any lint build-up. there should be very strong flow of air out vent with hose removed.
J
Jun 10, 2008 | Maytag PYE2300AY Electric Dryer
MAYTAG PERFORMA PYET244AYW
It could very well be a thermostat problem, however, it could also be the drive motor itself starting to burn out. Some dryers are equipped with a "Thermal Limiter" that will cut the power to heat. It doesn't seem to be the case for you. I would defiantely look into another thermostat but if it comes down to the motor, depending on the price, You may want to buy a new dryer.
Apr 01, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
