Question about DFI LANPARTY DK P35-T2RS LGA 775 Intel P35 ATX Intel Motherboard
Does not boot up, power supply is definitely working. Onboard led is one, but ram slot led is not. \ What's wrong?
    Novelist:
  • 89 Answers
Hi, Please do one thing, make sure that all the wires are properly plugged into the mother-board. As the light on the mother-board is on remove the ram(memory) from the board. If you have more than one ram(memory stick) installed then try changing their slots first and then if it doesn't work, remove them one by one and and change their slots. It should take care of the issue. Otherwise try changing with a new ram, if it also doesn't wok then you have to check with the local technician as the problem is with the mother-board. Hope it Helps. Regards. Anand Sachan
Posted on Nov 07, 2010
Why is my Dell Optiplex 320 indicating orange led and not booting nor display?
check the ram.change the slot and disconnect the hardrive before that
Apr 19, 2012 | Dell Computers & Internet
HI,I have a foxconn 45CMX Motherboard of a pinless 775 processor type,has two RAM slots ,16xPCI-E1,1xPCI-E1 slots and two PCI solts where I plugged my tv Card, 4 SATA slots and 1 IDE solt, it has a...
Hello nvukeya
You have described the computer very well in details.
as for the problem what i understand is that the only light coming on at the front of the case is the power light.
From past experience this problem is caused by one of two things.
1- faulty power supply. even though the power light comes on the power supply can be faulty
2- faulty motherboard.
While I am sure it is one the above items still you can go through the process of elimination.
To eliminate other components you can remove the TV card an if you have a floppy drive make sure to disconnect that too. then the computer. if you have more than one stick of RAM you can try them one at a time.
hope this has put you in the right direction.
please leave comment if this has been helpful
Dec 23, 2010 | Foxconn 45CMX socket LGA775 motherboard...
Emachine dead only fans and constant orange light work.
Does the orange LED go green when the machine is working? if so take out the system ram (memory) clean the contacts and the slots, reseat the ram and try to boot up.
Good luck.
Jul 14, 2009 | Computers & Internet
No video mouse or keyboard but all power and leds are working
there are several problems to this case.
1. check the 24 pin power supply and be sure to plugin the 4 pin power supply just beside the cpu.
2.ram not placed correctly
3.Power supply inefficient.
4.BAD BIOS SETTINGS Try resetting bios i.e.., CLEAR CMOS or remove onboard battery, wait for a while and then place it again.
5.RAM is damaged
6. Highly overclocked cpu - resetting bios works
Check all the above to see whether your computer comes online.
6.
Apr 22, 2009 | ASUS P5GC-MX/1333 Motherboard
Monitor is not on
Im gonna take it that "yup i'm hear the any beep" means you do hear a beep.
So first If it has an onboard vga card. remove the second vga and hook the monitor up to the onboard and try to boot.
Second try the Power Supply, make sure whatever power supply you use has enough to handle all the equipment in the unit.
If those two don't solve the problem, then you have a bad motherboard.
Mar 17, 2009 | Gigabyte GA-8I848P-G Motherboard
Computer will not startup
H there.
The beep codes you describe sound like memory issues or failure, take the system memory out, clean the contacts and the slots with a clean, soft, dry paintbrush. Re-seat the memory firmly and try boot the PC again.
Please post back with the results
Good luck and thanks for using Fixya!!
Mar 16, 2009 | Computers & Internet
ASUS MOTHERBOARD P5B-MX WIFI WON'T DISPLAY
Are you sure the onboard video is working? Try an external card and see if this works. All the beeps when you remove the memory is good because you know the processor is working.Are you sure you have the right memory? Some machines won't boot or anything when you have the wrong memory.
Dec 13, 2008 | Computers & Internet
Model pasaris motherboard D865GBF system restart
remove all components except the main hard drive and all cards.
If it has onboard display and you have a graphics card remove the graphics card and use the onboard.
remove all RAM except one.
Check if it boots now, if not, swop the RAM around and try again. If you dont have spare RAM get some and borrow it.
also reset the bios to defaults as well, you may have a wrong setting for whatever reason.
If you have it booting up now, add one component at a time untill the problem returns.
If it doesnt you just had something loose.
Check also to make sure your power supply can supply enough power.
If this doesnt solve the problem let me know WHEN in reboots... while loading the operating system ? before ?
Nov 21, 2008 | Intel D865GBF Motherboard
Asus p5ld2-wm and coroe
Sounds like a RAM or power supply problem to me, check the ram... even if it is brand new
Aug 21, 2006 | ASUS P5LD2-VM Motherboard
DFI LANPARTY DK P35-T2RS LGA 775 Intel P35 ATX Intel Motherboard Logo
182 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Steve Frost
Steve Frost
jason
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
