Question about SanDisk 2GB microSD Memory Card
2gb sd card not detected by pc & camera - SanDisk 2GB microSD Memory Card
    Scholar:
  • 179 Answers
Install proper drivers for the sd card..
Posted on Nov 08, 2010
Says sd card error
Are you sure it's an SD card? Even though SDHC cards will also fit into the slot, they will not work in the A540. If the card is larger than 2GB then it will not work.
Feb 03, 2013 | Canon PowerShot A540 Digital Camera
Canon IXUS 970 IS will not recognise 2GB SD card although it used to do so
The memory card might have been damaged.If it was a problem with your camera it might not have recognized your 32k sd card.
So buy a new sd card.
Jun 10, 2012 | Canon IXUS 970 IS Digital Camera
2GB MICRO SD CARD NOT DETECTING IN MY FORME MOBILE
Check the SD card on the laptop or PC using the card reader. If the card is detected then format the card and see if the properties show full storage.
now try and insert on the mobile and if this is not seen there is support for the card from the phone.
Jun 14, 2011 | SanDisk 2GB microSD Memory Card
My card is not detected when put in to the pc it not opened what i do give me any solution.My memory card is sand disk 2gb micro sd card
It would be a good idea to test the memory in another PC, if the problem continues, the SD has a file system that isn't recognized by your operating system or it has a bad file allocation table, if can be read only from a phone, camera or PDA , and it has data, you can use the corresponding device acting as reader connected to PC using its USB cable to retrieve your data from the card.
Feb 26, 2011 | SanDisk 2GB microSD Memory Card
New 4G memory card states full have re-formatted but still shows full. Have tried a 2G card but that is ok to use any ideas please
Your new 4GB card is an SDHC card. The S700 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with cards 2GB and smaller.
Jan 10, 2011 | Samsung Digimax S700 Digital Camera
Is there a way to get the DC E53 camera to accept a larger SD card than the 512mb that it currently accepts?
The following link describes the maximum SD card size for your camera.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/BenQ/BenQ+DC+E53_Memory_Cards
The following is from their site:
BenQ DC E53 BenQ DC E53 Memory Cards (SD Card) & Accessories
The following digital camera memory cards are compatible with your BenQ DC E53. Every digital camera memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty.Your BenQ DC E53 accepts SD Card cards.The largest SD Card card you can use in your BenQ DC E53 is 2GB
So you can buy up to 2GB SD cards.
Jan 05, 2011 | BenQ DC E53 Digital Camera
Dear Sir / Madam, I'm using this camera, in its manual it is stated that it supports 1GB SD Memory Card but I tried it with 2GB SD Memory it is detecting and working so should I continue with it or else...
The 2GB one will be ok. When your manual was written, there probably weren't any 2GB cards around, so they only mentioned the 1GB.
However, 4GB or larger "SD" cards won't work. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Dec 25, 2010 | Cameras
How much of memory it supports. Not detecting 4gb microsd when used with adapter.
The EX-P600 is designed to work with SD cards (and microSD cards via an SD adapter). Your 4GB card is actually a microSDHC card and is not compatible with SD devices. You need to go with SD cards (micro or otherwise) 2GB and smaller.
Sep 17, 2010 | Casio Exilim Pro EX-P600 Digital Camera
When I put in my SD 8 GB memory card, busy signal
An 8GB SD card will actually be a SDHC card, the HC means High Capacity. Your camera is only designed for regular SD cards up to a maximum capacity of 2GB; it's incompatible with SDHC at the basic hardware level and so cannot format the card.
You only have one solution: fit an SD card which does not exceed 2GB. Note that the specification for regular SD cards goes up to 4GB, but very few standard SD devices were ever designed or tested for compatibility with them. The few regular SD cameras which can use them mostly can only do so after a firmware update and even then will operate very slowly compared to when using a 2GB card. There has never been a firmware update to enable your camera to use 4GB SD cards.
I hope that you have found my posting to be of assistance and ask in return only that you return the favour by rating my answer.
Nov 01, 2009 | Jazz JDC87 Digital Camera
SanDisk 2GB microSD Memory Card Logo
443 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
