Question about IBM ThinkPad A30 2652 Notebook
My monitor shows display but the lights are off so it is dark. but if i press the button for hibernation that is located to the upper right of my IBM a30 and releaase it the lights will turn on for a seconds and then turn off again. i dont know what is the problem but i am hearing screeching to the LCD inverter. it just happen yesterday nov 05 2010 while i was surfing the net. kindly help me with my problems. thanks and regards, arnie crisostomo
  • 105 Answers
SOURCE: LCD and inverter replaced, still dark
The most common fault here is certainly the screen cable - it is available cheaply on ebay - I'm in the UK so here is a local example in this link:
T23 Cable
the other slim possibility is failure of the backlight switch which detects when the screen lid is closed.
Please rate this assistance as we depend on your feedback - hopefully this should be fixya - thanks,
Posted on Mar 24, 2008
SOURCE: IBM ThinkPad T21 LCD display very dark
I had the same problem with my T21. I also had to close and open the lid a few times in the beginning, but after a while even that didn't help anymore.
So, I took the whole thing apart, and what I expected turned out to be right: the ribboncable going to the display was cracked where it leaves the lid and goes into the pc-case.
It is possible to repair it (I know, because I did) but if you're not used to work with a soldering iron (and your eyes are in perfect shape), don't even try. These contacts are so tiny that I had to work through a magnifiying glass all the time.
First, you have to remove the outer shell of the ribboncable. The easiest way to do that is with one of these highspeed rotary tools. (Note that this shell is made of conductive material, watch out with the debris)
When the cover is removed, you can see which traces are broken. Before you can solder the broken ones, you have to remove the varnish from them. That can be done with a sharp knive. Be very careful, because the copper layer underneath is very thin.
In my case, four of these traces at the side of the cable were broken (varying in size between 1/2 and 1.5 millimeter).
I soldered some copper wires over the fractures, and that did the trick.
It works again!
Biggest challenge now is to get it assembled again :-)
Succes,
JVdB.
Remark: If opening and closing the lid solves the problem for a while, you can be definitly sure it is the cable, and not the inverter or the LCD.
Posted on Jun 06, 2008
SOURCE: IBM T30 LCD replaced - now LCD display not right resolution
You might want to Flash the BIOS with the latest revision if this is a newer LCD.
Posted on Nov 21, 2008
cpenzes
  • 1102 Answers
SOURCE: IBM t42 Display problem
Sometimes there are keys are your laptop that adjust your settings.
If you know which keys you can hit the fn key simultaneously.
If your not sure go on line and you should be able to find a site that will tell you how to adjust your screen.
In search type your laptop model then type display settings
Posted on Jan 13, 2009
ruben_barrer
  • 117 Answers
SOURCE: IBM R51 Backlight Problem..
check the model/part on the inverter. if you know you have a good one on the second laptop, remove it and try it in the non-working one. if the parts match which most of the time they do, then you are ok, it should only be two wires on the inverter, one coming from mobo, one coming from lcd. if that doesnt work you have blown a capacitor/resistor somewhere down the line. in that case it will have to be serviced and will run you anywhere from 80-130 if you find a place local or on ebay.
Good Luck!
Ruben
Posted on Jul 23, 2009
What causes laptos to not show display despite showing that they have switched on?
Step 1:
The display on your laptop is the interface through which you interact with and control your computer. If it is not working, your laptop will become virtually impossible to use. A laptop is a computer, and like all computers is subject to both hardware and software problems that may affect the display. Before taking your laptop in for repair or getting rid of it, you should first check the display yourself to see if it needs to be replaced.
Check the laptop's battery and power cord. If the laptop is out of power, the display will not work. This usually happens if the power cord is unplugged and you were unknowingly running your laptop on battery power. Check to make sure the power cord is plugged in and that the laptop has power. Many laptops also turn off the display if it is being powered by its battery after a period of nonuse. Touching any key will usually turn the display back on if the battery is not drained. Restart your computer. If a software program is stuck or malfunctioning, it may cause your display to stop functioning. Press and hold the "Power" button on your laptop to reboot your computer. If the problem was a malfunctioning program, the display will turn on after the computer restarts. Check the brightness level of the display. If the level is too low, the screen will appear dark. The brightness controls are usually located on two function keys, such as "F9" and "F10." Look for sun or light icons on the keys. Press the key with the larger icon to increase the brightness level. Alternatively, on some laptops hold the "Fn" key while simultaneously pressing the "Up Arrow" key to increase the screen brightness. Check the display closed switch. Many laptops have a small button that senses when the LCD screen is closed and puts the laptop in sleep or hibernation mode. If the switch gets clogged with dirt, it may get stuck in the closed position. This will result in dark display even when the lid is open. The switch is usually located near the hinges of the lid. Spray the switch with a can of compressed air to loosen the dirt so that it will resume its normal operation. Plug an external monitor into your laptop. If the problem is not software related, the external monitor will display the laptop's screen. Connect the monitor by plugging the cable into the VGA, HDMI or DVI port on the laptop. Press and hold the "Fn" key while simultaneously pressing the "F8" key. The video output will be directed to the external monitor if there is a hardware problem.
b>
Feb 21, 2013 | Toshiba Satellite Computers & Internet
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
My screen for my TI-83 is turning black and I can't get it off
How to Change the Brightness of the Display
To darken the display, press the yellow 2nd button and then press and hold down the Up-Arrow button located in the upper right section of the keypad. Release the Up-Arrow button when the display has reached the desired level of darkness.
To lighten the display, press the yellow 2nd button and then press and hold down the Down-Arrow button. Release the Down-Arrow button when the display has reached the desired level of lightness.
As you go through this process, a number will appear at the top right corner of the display. If this number is 7 or higher when your screen reaches the desired level of brightness, then your batteries are getting low and may need replacing soon. This number will be approximately 3 or 4 for new batteries.
Jun 17, 2011 | Texas Instruments TI-86 Calculator
Desktop is continuing to display contrast as 100
Dear mahendra
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor botton circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.It deffinately solves your problem.
Good Luck
Fixya Customer Support
Chandrashekhar
Jul 22, 2009 | IBM E54 15" CRT Monitor
My think pad goes dark after the windows logo...
Right click on te screen and click on properity in the screensaver tab check the power setting to make sure it is not set to hibernate if so un check the boxs and check the shutdown time
Apr 21, 2009 | IBM ThinkPad T20 2647 Notebook
Hibernate
When Windows opens then -
Open Control Panel - then click on Power Options - Click on Hibernate tab and uncheck Enable Hibernate - Click OK
Feb 13, 2009 | IBM ThinkPad T23 2647 Notebook
IBM T30 screen has gone dark .
Above the upper right corner, there is a littlesquare nutch that turns the screen dark when the lid is closed. In most cases it's stucked. poke it with a pen and see if the light turns on.
Sep 19, 2008 | IBM ThinkPad T30 2366 Notebook
No visual display
Function F7 will enable the external video monitor connection and will toggle between the screen, the screen plus external monitor, and the external monitor only. Try hitting function F7 and see if that helps. Also there is a small switch that is activated when you close hte lid to turn off the display when the lid is closed. make sure that this little switch is not stuck.
Dan
Mar 21, 2008 | IBM ThinkPad T23 2647 Notebook
IBM ThinkPad A30 2652 Notebook Logo
42 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
