Machine genesis 511 5kg model 36s511e.01 wont adgertate trys every thing else works fine
  • davidbatt182 Nov 07, 2010
    Thanks Joe were thinking that might be the case
  • 1,998 Answers
Hello ok so this is a top load model and top load models when they dont adjetate are caused by a couple different reasons first is your lid switch working properly one way of checking is to open and close the lid and listen for the click in the switch another way would be to take off the cover and connect the two wires together that went to the lid switch with a jumper wire. After you connect the two wires with the jumper then set the machine to adjetate and pull out the dial if your machine still does not spin then you might have a drive couple problem which is what connects the motor to the transmission of the machine here is the link note this might not be how to remove the cover on your machine on this video http://www.youtube.com/user/RepairClinic?v=9K1KHEogf3c&feature=pyv&ad=5501893181&kw=washing%20machine%20coupler&gclid=CP7xg5rszKUCFRNSgwodvDf2kw the final thing that could be wrong would be the timer but i dont really think that this is the problem because the machine would be doing other problems as well so first check the lid switch then check the drive couple and message me back with your finds Please remember to rank how this opinion has helped in your appliance situation and have a great day
Rick
Posted on Dec 02, 2010
  • 10,865 Answers
Hello David. When it will not aggitate, the transmission is bad. The cost of the part and the repair is high and prohibitive in most instances. Your best bet is to replace the washing machine. Joe
4 thumbs up please. ty.
Posted on Nov 07, 2010
Won't spin gw608u
Fault code 41 if those are the correct lights. Service manual says faulty temperature thermistor & change the control module. Good luck with that as that model is nearly 20 years old and I don't think F&P supply that module any more.
May 02, 2017 | Fisher and Paykel GWL11 Top Load Washer
Will not spin only adgorates gw608u
Hi just read your post.Now your post has indicated the lights that are on while it is beeping are from LEFT to RIGHT are 3, 5, and 8.Is this correct.Please reply back if this is correct and it should not be hard to rectify Looking forward to your post,Lu
Jan 24, 2014 | Fisher and Paykel GWL11 Top Load Washer
Won't spin gw608u
You need to call a repair person. Or if the washer is still on warranty trade it in. This sounds like a problem from the factory
Sega Genesis Model 2 won't turn on
Well it sounds like that you have a bad ac adapter then so buy a new ac adapter the console is fine so just a new adapter that's all.
Apr 28, 2012 | Sega Genesis Console
Wont come on
Man I haven't seen an actual Sega Genesis console in years. Anyways...
1) Make sure that everything is plugged into your system properly. 2) Check you make sure your TV is on the right channel 3) Check to make sure the fan is at least powering up when you turn on the Genesis. If it is then the Genesis is working. 4) Plug something else into the TV to make sure it works.
Remember, HDTVs and LCDs and this whole Al Gore's Gone Green thing wasn't around when they made the Sega Genesis, so conventional means to playing a Sega aren't your best option. Don't plug it into the wall either, make sure you are plugging it into a surge protector.
Hope this helps.
Jan 01, 2011 | Sega Genesis Console
Sega Genesis continually scrolls vertically on Toshiba tv
you need to have a small crappy tv unfortunatly....your 52" wont support it...also you may need to fine tune or find another channel GL
Apr 02, 2010 | Sega Genesis Console
Sega Genesis not displaying correctly
mine did the same thing. check the video cable, make sure it's in good condition and try to repair RF switch as best as you can.
Jun 24, 2009 | Sega Genesis Console
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
