Question about Nintendo GameCube Console
My disc is not spinning when i turn it on? what's wrong?
    President:
  • 894 Answers
Well its most likely that the motor is shot for the console.
Posted on Aug 25, 2011
I get the message: "wrong
Wrong disc/No disc error can be a DIY like the following steps.
Assuming that the disc is good.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact/lead by pencil eraser.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I
Jan 23, 2011 | GPX D1816 DVD Player
DVD display says "Wrong disc" no matter which disc
Leave dvd player on for a lengthy time to dry up condensation, may take a few weeks?
Dec 01, 2010 | Norcent Technologies DP313 DVD Player
DISC DOESN'T TURN ON MY WII
you should probably check the wii system or check the disc if you put it in wrong
Aug 27, 2009 | Nintendo Wii Console
My playstation 2 disk tray wont spin
the thing is, there can be 2 things.
  • The motor that spins the discs has gone bad. you cant do anything then, just pay the local dealer 20$, he'll fix it for ya
  • Or, your Disc tray is not closed properly. For solving this, try to keep somehitng heavy upon the disc tray, and then try.
  • Please give ratings promtly :)
Mar 27, 2009 | Sony PlayStation 2 Slimline Console
Protron says wrong disc
there are so many reasons to that legend,dirty laser lens,capacitor dried on the electric feed board,flat connector between the laser lens and the board,bad motor spin disc.good luck
Mar 19, 2009 | Protron PD-007 DVD Player
Wrong disc
If this model displays Wrong Disc even when you play all kinds of CDs, you may want to buy a CD/DVD laser cleaner for it.
Does this solve the problem?
Aug 03, 2008 | Coby TF-DVD7005 Portable DVD Player
Disc not spinning
Clean lense with alcohol and soft cloth if you can carefully move eye to the start position and then clean. Try again.
Sep 24, 2007 | kawasaki PVS297OS
Dvd player will not spin disk
Unfortunately, your DVD player is broken. Portable units like these often get bumped and jostled and the motor that spins the DVD quits (very small and fragile). Sorry, I wish there were a magic button.
May 15, 2007 | Coby TFDVD5000 Portable DVD Player
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Feb 02, 2007 | Centrios EDW8020 DVD Recorder
Nintendo GameCube Console Logo
73 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
