My laptop has 18 viruses and I can turn it on but it locks up and the cursor disappers how do I reboot it
    Master:
  • 969 Answers
During re-boot press F8 continuously until boot option window appears. You will know it accepts F8 command when the computer beeps. Run in Safe mode.
Posted on Nov 07, 2010
How do I fix cursor. When I use my cursor some times it want respond to the location I need it to go.How can I fix it?
Instructions
    • 1 Close all application windows and restart the laptop. This will shut down any background processes that might be affecting your cursor. Rebooting often remedies cursor skipping problems.
    • 2 Run antivirus software to confirm that your misbehaving cursor is not caused by malware. If the cursor has changed to an unfamiliar shape without you initiating the change, your system could be infected by a virus or you might have installed unstable software. Run an antivirus scan and remove suspicious files and programs from your laptop.
    • 3 Adjust your touchpad's settings. In Windows, open "Control Panel," click on "Mouse" and then click "Tapping." On a Mac, access "Trackpad" and "System Preferences." Lower the tracking speed or sensitivity so that if you are accidentally touching the touchpad while typing, you are less likely to cause the cursor to skip. Save your new settings.
Oct 01, 2014 | Toshiba Computers & Internet
The cursor will not move I think I have locked the touch pad by mistake
Use a temporary external USB mouse, Click Start button from your laptop. Type "mouse" in Search Program & Files, click mouse under control panel. click Hardware tab,click properties, click change settings, click driver tab, check if the device is enable or click update diver or rollback driver if necessary.
Aug 25, 2014 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Cursor freezes on my philips x72 laptop. Went to bed it worked fine . Switched on next day and after welcome to windows it asks for username password etc. Cursor will flash until i try and enter text. No...
If you don't normally enter a password, reboot in safe mode and choose a time before it went wrong with Restore Point. Then use an anti virus program to clean up your system.
May 27, 2014 | Computers & Internet
Laptop cursor lock key
Normally you need to hold the left CTRL Key plus the left shift key. While holding these two look for the button that say scroll lock or cursor lock and hit that one. This will turn it off.
Apr 09, 2014 | Fujitsu Siemens Computers & Internet
Keyboard jumps up to line just typed
Sounds like you have a sticky up arrow key,or you have a virus on your comp.Try booting in safemode by turning on your computer and tapping the F8 key while booting,then choose safemode.Once you are in Windows,open the program you are using and try your text document again.If it works correctly,you may have a virus.While you are in Safemode,run your virus scanner,then reboot your computer to see if the problem is solved.If it does not fix it,try running System Restore back to before the problem started.Good luck :)
Apr 22, 2013 | Everex StepNote VA4103M Notebook
How do I turn on the numlock on my HP ProBook 4525s? I press the numlock key with no results.
from bios, /setup/ , there will be Num lock - disable, change yo enable, or read it,
http://www.pdspc.com/digitalcontent/USER_MANUAL/1b912539-e1cd-412d-ad8a-758270f5458e.pdf
Jun 03, 2011 | Computers & Internet
Cursor freezes
YOU MAY WANT TO CHECK THE TEMPERATURE OF THE CPU BUY RANDOMLY REBOOTING AND ENTERING SETUP TO CHECK CPU TEMP IF THE FAN OR CHANNEL ARE NOT ALLOWING AIR FLOW THEN YOU COULD BE SUFFERING FROM A OVERHEAT AND THE SYSTEM LOCKS, HAD A SIMILAR PROBLEM WITH WIFE'S LAPTOP. YOU MAY BE ABLE TO GET MONITORING SOFTWARE FROM THE MAIN COMPANY OF ANY LAPTOP.
Aug 20, 2009 | Acer Aspire One PC Notebook
When I turn on my gatway md7818, it boots up but screen is black except for the cursor arrow
Check your time setting on Bios page.
Try to run F8 to safemode, scan your computer or defragmented
You may have spyware or virus is keeping you away from booting.
Check your memory size, you may need to maximize your memory.
Jul 28, 2009 | Gateway M305CRV Notebook
Computers & Internet Logo
David Payne
David Payne
