KDFE55A20 Sony Turn power on. Picture is on for about 15 sec then the picture goes off, can still here sound. maybe 30 seconds go by picture comes back on then back off . continues to do this. Fan is running picture looks fine when it comes on...just wont stay on.
  • bryon nance Jun 15, 2008
    It had been fine since I bought it. TV has not been moved for 2 years. I pulled out the lamp and plugged back in, but no help.
  • 8,617 Answers
Check the connections that plug into the Block assembly. sounds like a connection issue.
Posted on Jun 15, 2008
  • Sonny Berry
    Sonny Berry Jun 15, 2008
    If it hasnt been moved, It will need to be properly diagnosed as that unit has whats known as a block Chassis where all the boards are packaged in one Block housed inside a metal box.Very difficult to service
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Picture and sound come and go on antenna or dvd
Try another lamp. Error 5 is Lamp power supply, but its usually always the lamp bad.
Mar 27, 2014 | Sony Grand WEGA KF60WE610 60" Rear...
I have a SONY KDFE55A20 TV. The picture and sound go blank and come back on in about 30 seconds. I get a red flashing light only if I turn the tv off and back on. It flashes 5 times and repeats. The bulb...
Sorry friend, but the only sure thing is that you're getting a lamp driver error. Odds are you're either having an issue with the ballast or your power supply can't supply the voltage needed. If you're good with electronics you can check the voltages on the power supply and try to rule that out. Otherwise you should take the set in for repair. Good luck.
May 05, 2011 | Sony Televison & Video
Tv turns on, picture disappears after a few seconds, turn off tv, and then on, same problem picture is fine, the disappears after a few seconds
You may have either failing 24vdc power supply or the backlight inverter board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Aug 07, 2010 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sound but no picture
hi
i think its a colour wheel problem...if there is led blink tell me how many times it will blink i will sort if there is error code and i will tell the solution
Feb 14, 2009 | Sony Televison & Video
Sound stays on picture goes out
it would probably be easier to have someone come out and take a look at it before you go buying parts you may not need to be spending money on. it may be a simple fix for a repairman and not so simple for you...
Feb 14, 2009 | Televison & Video
Standby mode
I have the same television. Mine would shut off and turn back on every 30 seconds. Even though the LAMP light wasnt coming on in the front of the set, I replaced the lamp with a factory Sony lamp and have had no problems since. The sets picture is beautiful and I have had no problem since.
Aug 03, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony LCD Projection TV turning OFF.....help!!!
Look carefully at the front lights. Usually when these sets shutdown they have a blink code on either the standby light or the lamp light. Update this with those counts. In the meantime, you may be seeing a problem with heat. If the lamp area gets too hot, the set will shutdown the lamp. Once the area is cool again, the lamp will fire.
Update this and we'll hopefully fix the both of them.
Dan
Apr 09, 2008 | Televison & Video
Sony kdfe55a 20
2 YEAR IS TIME TO RPLECE LAMP
Mar 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Televison & Video Logo
120 people viewed this question
Top Televison & Video Experts
