Question about Hitachi 53UWX10B 53" Rear Projection Television
3D picture problem
I have the same problem you had with your hitachi , what did ypu do to fix ? thanks!
  • 4,234 Answers
This is a problem with the convergence circuit. If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. These ICs are large and black, attached to a heat sink and are marked STKxxx.
Keep us posted on your progress.
Dan
Posted on Jun 19, 2008
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
How to fix the color on the Hitachi TV model # 5OUX15 X?
It is a older Hitachi---what do you have---color is skewed or even looks 3d?
That if the case is a convergence problem. See typical photos--no two will look exactly the same but the pictures should tell you if this is your problem or not.
May 15, 2012 | Hitachi Televison & Video
Is it worth repairing a hitachi 51s500 projection tv purchased in 2003 that has a blurry picture?
If convergence or 3d looking etc it is not only worth fixing but can be a do it yourself repair.
The picture looks like it is in 3d
If your TV looks 3D or warped your convergence has gone out. You will need to call in a shop or get a DIY convergence repair kit from www.TvRepairKits.com to fix it.
Jan 17, 2012 | Hitachi 53UDX10B 53" Rear Projection...
We have an 80's hitachi mts 52" tv/ monitor and it has a 3d effect how do we fix this?
Tv have a problem known as convergence problems,it dead.Tv R,G,B colors lines mis alignment,Colors shadows or 3d pictures effect.The tv convergnce board is dead.The tv convergence board,require replacing 2 STK convergnce ICS and some or all it resistors.To solved tv convergence board,to solved tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Sep 11, 2010 | Hitachi 53UWX10B 53" Rear Projection...
I'm getting an overlapping of two colors on the screen.
It is common problem with rear projection tv and 3D type picture problem occurs due to failure of convergence output ICs, replacement of convergence output ICs will fix the issue and tv will again show correct converge picture as before.
Let me know tv model number written on back of tv if you want to fix tv by yourself as it needs soldering parts in circuit board expertise and if you feel uncomfortable working in tv circuit boards than local tv repairman will do this job for you.
Thanks.
Jun 30, 2010 | Hitachi 61SWX01W 61" Rear Projection...
3d look with little bending in bottom left corner of screen.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 04, 2010 | Hitachi 52LDX99B 52" Rear Projection...
Picture is fuzzy for the first few mins after turning on
This may be an issue with your color wheel where it isn't spinning up to speed at first but finally does after the 2 - 10 minutes. Fairly common in DLP TV's.
This could be fixed by a qualified Hitachi Servicer.
Blessings,
A/V Media Tech Guy
Nov 21, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Double picture 3d
You need new Convergence ICs post the model number and I will post the numbers you need and where you can get replacements with free instalation instructions with pictures
May 13, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
