Question about Dell Inspiron 1420 Motherboard - KN548
When i conect charger to laptop then charger green light is off
  • Dell Master
  • 32,281 Answers
The adapter could be faulty or the power socket on the laptop could be faulty. Please click on this link and follow my instruction to determine the fault and fix :-
http://www.fixya.com/support/r4799950-laptop_battery_power_supply_problems
Posted on Nov 07, 2010
New battery when put on charger blinks red and green light
that indicates the battery has failed ,sadly and unless than 1 year old it is junk. Batteriesplus will not repair them.
Jan 22, 2015 | Makita BFR750 18-Volt LXT Lithium-Ion...
How can you tell if your laptop battery is dead,or that your charger is bad?
Hi, if your mains plug has a fuse, I would check the fuse, if thats ok, put a multimeter on to the end of the of the charger lead and check for around 19v, it will say the exact voltage output on the sticker on your charger.
The green light malfunction indicates a issue with the charger not the battery.
Hope this helps
Best of luck
May 31, 2012 | Dell Computers & Internet
My Acer extensa 5620Z laptop will not turn on
it seems your charger is not working, try to check it with another power adapter
Oct 23, 2011 | Acer Extensa 5620 Notebook PC
My laptop charger to acer 5930 stopped working in the middle of the night. The green light on the power supply lights up clearly when I insert it into the outlet. But as soon as i plug in the charger to my...
Remove the battery and try again.
If the laptop works ok with the charger connected (with battery taken out), then the battery needs to be replaced.
Refer to user guide on how to remove the battery.
Jun 24, 2011 | Acer Aspire 5930 Laptop Charger...
When I turned on my laptop today the screen did not turn on. The green light is on, on the keyboard so looks like the computer is on but there is nothing on the screen. Any suggestions
try to do a power drain by removing the battery and anything connected to it..> press power button for 1minute > plug back in the charger and after few secs try to turn it on...
May 12, 2011 | Toshiba Satellite L500 Series Notebook
I can not even get the thing to come on the green light comes on but nothing ele
try to do a power drain by removing the battery and charger(also whatever conected to it) then press power button and hold it for 30secs..then plug back in the charger and try to turn it on..hope this helps :D
Mar 18, 2011 | Sylvania G-Netbook
Green light cuts off when plugging into laptop
Replace the charger, it probably overheat and died.
Try with a voltmeter to measure the output power (usually aroud 19 V DC)
Then the tricky part, try to power something else with the charger , something who might work with the output power (a car light bulb for exemple).
If it does work then you have a short cut on the motherboard of your laptop if it's the case replace the laptop, it's the hell of a job to repair the motherboard...
good luck
Dec 12, 2009 | Dell Inspiron 1501 Laptop
How i can check the dell nps-460bb power supply working or not?
If there is a light on it and its on, its a start, if you have a volt meter u can get a reading from the conection that goes into computer. check the pins inside this conection with a pen see if they are loose, another way is to place the black box againts ur ear firmly listen carefully for a hum, if its hummmming then its working, if the charger aint pwoering the laptop check the conection that goes into laptop for any loose parts, another problem can be the laptops conection its self , give it a sligh push to one side or the other to see if it lights up the laptop, or try it in another laptop that uses the same conection.
hope this helps in some way.
Dec 02, 2009 | Cars & Trucks
I have a Medion 221o. When the charger is plugged
there is 3 possible problems i think here, one the conection to computer is faulty, 2 the battery it selfs is busted wont hold its charge, 3 there is a switch that decides charge and no charge on main board and its faulty, if its number 3 its a big problem very hard to replace if you have warenteee that is your safest bet or search ebay for a secound hand board, 2 try another batter to see if it holds the charge, 1 wiggle the conection to see if you see any charge goign to batter at any one time, is all i can say to help you here. hope this helps
Nov 29, 2009 | Computers & Internet
Dell Inspiron 1420 Motherboard - KN548 Logo
83 people viewed this question
Alun Cox
