Question about Samsung SC-D353 Mini DV Digital Camcorder
Camera turning off
My will not turn off. Even when in the off position it is still on, so I have to remove the battery otherwise it keeps draining the battery. when it is turned to off you can still watch the pictures on the lcd screen as if you are taping. it worked fine until one day it just started doing this and we have only used the camera a handful of times.
  • Tim Babcock
    Tim Babcock May 11, 2010
    If you take the battery out and plug it into an electrical outlet, is the camera running normally?
Yes it works fine, even with the battery in and plugged in it works, if the battery has a charge i can unplug it and it works fine. the camera will just not shut off.
Posted on Jun 15, 2008
Menu screen nothing but lines.
Turn camera off, remove battery's and sd card. With everything out turn it to the on position for about 2-3. After 2-3 minutes put batterys back in while on the on position. Once he says no card or no memory turn the camera off put sd card back in and test the camera.
Mar 02, 2014 | Moultrie Game Spy D555i Trail Camera
I keep getting a SUD error, I have stopped the cycle and reset by unpluging the washer, it keeps showing the SUD error. What should I do?
This code indicates that an apparent sudsing condition is detected. It happens when a non-HE detergent is used. Run a cycle without detergent or allow the machine to fill then drain it to make sure suds are removed. The problem is in draining if the code still flashes even no detergent is used.
Unplug the machine or disconnect power then remove the three screws attaching the bottom of the lower front access panel and pull the panel down and off. Once the panel is off, you'll find the drain filter attached to the drain pump.
Place a container or a piece of towel underneath the filter to catch spillage. You may need to drain the water from the machine by putting the end of the drain hose over a container on the floor. Position the container as low as possible to extract as much water.
Remove the filter by turning the knob counterclockwise and clean it. Also take a moment to inspect the drain pump impeller by reaching it in with your finger and turning it. The impeller should turn freely. Otherwise, replace the drain pump.
This Kenmore machine is made by Whirlpool and therefore troubleshooting is basically the same. Click on link below for more detailed drain problem troubleshooting.
Drain Problem Troubleshooting on Whirlpool-made Front Load Washing Machines
Jul 20, 2011 | Kenmore Elite HE5t Washer
I just set the date stamp in the on position. Then, turned the camera off as I didn't need to take a picture. Now, when I turn it on, the lense comes out and then immediately goes back in flush and the...
How long have you owned the camera? If under a year then I would recommend having it serviced by kodak under warranty. If it's over a year old you may want to try a new battery otherwise consider replacement.
Thank you,
Lee
Jun 13, 2010 | Kodak EasyShare V1003 Digital Camera
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
I have a lincoln ls 2000 the bttaery keeps draining the alternator is good front end damage hood and driver side light needs to be replaced what could be the problem?
Is there's sufficient damage to the hood, the hood switch that turns on the hood light is most likely damaged or tripped on due to the hood damage. This would drain your battery fast. Removing the light unit may interrupt the power. Otherwise, the switch needs repair.
Oct 20, 2009 | 2000 Lincoln LS
Kodak Z1085 IS - drains battery even when camera is not on
the camera takes 1.5v to operate it
anything less the camera will shut down
recharge batteries are only 1.4v so at full
recharge it won't last long
The best batteries are litheum that have the right
volts and capacity to keep the camera going.
try turning or the camera stablizer setting...
might save your battery power.
Mar 17, 2009 | Kodak EASYSHARE Z1085 IS Digital Camera
FX8 all button frozen
I am not sure if this is a solution. but one time, i turned on my camera when the battery is really drained. usually (when it was broken) it will automatically zoom in. but that certain period when i turned it on, even before it can zoom in, the battery drained and the camera went off. i charged the battery and when i put it back and turned on the camera, it works fine. it is still working fine. good thing i didnt had the repair center fix it, because they charge really high price.
Nov 11, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
The batteries were drained in my FinePix S7000 camera whthe camera was not in use.
The CompactFlash card may have caused the batteries to drain. Some solid state CompactFlash cards consume power while inserted in the FinePix S7000 even if the camera is turned OFF. Fujifilm recommends removing the CompactFlash card when the camera is not in use. Microdrives and xD-Picture Cards do not exhibit this problem.
Aug 29, 2005 | Fuji FinePix S7000 Digital Camera
Samsung SC-D353 Mini DV Digital Camcorder Logo
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
