Question about LG 42LB1DRA 42 in. LCD Television
I have a LG DLP Projection TV 132cm - Model RT52SZ60DB. The light flashes amber, I have a picture but NO sound. Please Help. Thanks
    Problem Solver:
  • 5 Answers
Check your input card then reset your tv in remote
Posted on Nov 07, 2010
LG DLP TV won't turn on
Your lamp has probably failed. You can buy a new bulb for under $100. http://projectorlamps.com/lg-zenith-dlp-tv-lamp-ru52sz51d-bulb.html RU52SZ51D Bulb LG Genuine High Quality Original Projector Lamps now...
Jun 01, 2015 | LG Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
How do you do a convergence on the wd73286?
Mitsubishi WD-73286 is DLP tv that does not have any convergence circuit inside.
Convergence is required in old model rear projection tv that has three basic colors picture tubes to generate color picture that projected on front screen of tv.
DLP tv has light engine to generate picture, it is similar to multimedia projector that throws its picture on wall.
Hope this info will help.
Thanks.
Mar 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Rca dlp hdtv widescreen - terrrible noise/flashing light
if its a dlp its most likely the color wheel that is causing the problem. Post your model number and i will assist you.Please respond to this same post.
Jun 22, 2009 | RCA P52926 52" Rear Projection Television
LG rear projection. RE-44SZ21RD - flashes amber
get a ohm meter and check all the fuses
Mar 27, 2009 | Televison & Video
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
No picture-lg ru-52sz51d
Depending on what light is flashing it could be a few things. If the Lamp light (the middle one) is flashing that is problem with or around the lamp. That orange or amber light is an indication that the lamp is reaching the end of its life
If it is the Temperature light (the far right one) then the TV is shutting down because it is over heating and you need to check the cooling fan.
Nov 14, 2007 | LG 52SX4D 52" HDTV
Resetting the indicator light
Hold down on the Enter or OK on the TV and Mute on the remote control for 5-10 seconds. The TV should then ask what you want to do. Perform this with the TV on.
Jan 31, 2007 | LG RU-52SZ51D 52" Rear Projection...
LG 42LB1DRA 42 in. LCD Television Logo
160 people viewed this question
Computer Repairing
Computer Repairing
