Question about Neff B1421 Electric Single Oven
Do all neff oven & hobs have to wired in using 6mm cable or can they be wired into a13 amp system
  • Neff Master
  • 3,463 Answers
If it is a single oven on it's own then it can be used from a 13 amp plug and socket, the same with the hob, if it is seperate from the oven it can be used from a 13 amp socket.
If it is a combined unit, then it will have to be hard wired to a seperate circuit using 6mm twin and earth cable, and fused on it's own circuit.
Posted on Nov 07, 2010
Have a neff t1213xo, what does black grey and brown wires stand for?
You have an hob with European three phase at 220volt mains wire connected.
You need to to disconnect from mains connection box on hob and fit conventional British brown, blue and green/yellow.
Inside the connection box you will see three live terminals,(L1,L2 & L3) there are usually some brass links to join them all up and then attach brown core to one of them. If the links are not there then you will need to fit 2.5mm links from a piece of wire.
Nov 24, 2014 | Neff Ovens
What size cable and fuse do I need to run a Neff oven 3.68kw. and induction hob 7.2kw together ?
Divide the total load by the volts available ie. 11kw by 240v or 110v, the result is current in amps. You need a cable of a suitable cross section to transmit that amperage. There is also a distance calculation to be considered as this affects the available load. Get a sparkie to guide you as to correct sizing.
Nov 04, 2014 | Neff Ovens
Hotpoint bd32 oven and top oven/grill what output does this have .and does it need 6mm cable connection or can it go on a plug
Hi.
You most definitely need a 6mm hard wired supply cable to cooker, anything less, and the cable will overheat .
Under no circumstances connect it to a 13 amp suupply and plug.
The total kw output can reach in excess of 4-5 kw, so it is imperative that you hard wire it to a seperate fused supply.
Jun 22, 2011 | Ovens
If i need 6mm feed to my neff double oven u15m62 why is there a 240v cable sticking out the back
Yes, the reason for the deeper shell requirement is for electrical connections. And that unit is listed at 240V so there will be a cable attached there.
Jun 07, 2011 | Ovens
Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
May 21, 2010 | Neff B1421 Electric Single Oven
Is 10mm cable ok from 4kw oven to connector unit
A bigger cable size (larger diameter conductors) will not affect power requirements of the stove. (A smaller one definitely will)
Regards
Nov 16, 2008 | Neff U1721 Double circotherm Electric Oven
NEFF HOB
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate. If you can locate the device, using a metal shield to divert some of the heat will help it serve its original function as a safety. Look for a thick (4-5 mm), button-like device with two terminals and a diameter of 1.5-2.0 cm.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
Oct 18, 2008 | AEG B1180-4 Electric Single Oven
Oven
You either have a bad element, loose wire or a short.
Start by checking the connection at the back of the stove.
Then look inside the oven to see if there is any visible evidence of damage to one of the oven elements.
I would suspect it is the bottom element that is giving you trouble.
Otherwise, if you have bad wiring to the range outlet, this could be difficult to track down.
If this is a new installation, your fuse/circuit breaker may not be high enough amps.
You may need to increase the size by installing new fuses or breaker depending on which you have.
I think a 50amp breaker would be standard, but you may need to use a 45 amp or greater. Just be sure your wire to it is heavy enough.
#6 wire would be better for a double oven situation.
Apr 03, 2008 | Neff U1721 Double circotherm Electric Oven
Neff B1421 Electric Single Oven Logo
643 people viewed this question
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
