Question about Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer
Frigidaire GLEH1642FS washer/dryer stacked unit: How do I disconnect the buzzer?
The buzzers (there are two, one for the washer, one for the dryer) are behind the control panel. 6 screws must be removed to access the back of the control panel: 2 for the service panel, the 2 outer screws at the base of the control panel, then the 2 much smaller-sized screws.
The buzzers, in my model, are small, un-buzzer-like-looking little black boxes stamped with the brand name 'Ark-less'.
The buzzer for the dryer is connected to 2 contacts on the back of the dryer timer, the contacts labeled 'H' and 'C'.
Once you've identified the buzzer for the dryer, you should be able to find the one for the washer. It's connected by one white and one grey wire.
You should be able to verify this info using the wiring diagram, which will be located behind the service panel. If I remember correctly, the buzzers were labeled 'signal' on the diagram.
Posted on Feb 27, 2011
Testimonial: "Thanks for the info!"
Turn off buzzer on frigidaire dryer LGR331SO
Good Afternoon Friend,
I understand that you want to turn the buzzer off of your Frigidaire dryer, model# LGR331SO. With your model dryer, you are not able to turn the buzzer off. I hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
On my front-loading stacked Frigidaire dryer, the clothes are coming out of the washing machine nearly dripping wet. What is the best way to deal with this?
Final spin does not appear to be working. Clothes are soaking wet after the buzzer has gone off. Any ideas would be helpful. Thanks.
Dec 21, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a 27 inch stacked washer/dryer unit, and want to disconnect the buzzer from the dryer, as it is way to loud !! so how do I due this ?? thanks Peter F.
pull the control panel off and behind there will be a black box with 2 wires disconect them and tape them up . also the box does not come through the front
Oct 25, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a frigidaire gleh1642fs stacked washer/dryer and the washer won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 19, 2010 | Frigidaire GLEH1642F Front Load Stacked...
My fridgidair dryer gleh1642fs felt pad wore out and dryer drum is ****-eyed now literally eating clothes up. funny how this happened after the warranty expired. how do I fix it? Also appears that the...
here ya go as far as getting the part.
https://www.repairclinic.com/Shop-For-Parts/-x676c6568313634326673/Gleh1642fs-Parts
they too have a very helpful chat or 800 team to answer questions many times when you select the part there is a install section.
Hope this helps. I know as I had this problem.
If you need directions I can help but tis a bit detailed.
maybe a youtube video on it helps to look when you know what part # your installing and what it's called
Have a good evening..
Jan 09, 2018 | Frigidaire GLEH1642DS Front Load Stacked...
Turn off buzzers
I had the same problem and the buzzer was one of the worst sounds ive heard. But, I found the buzzer and turned it off for good. Open the front panel and look for a small part in between the 2 main curcuit boxes.I have a Fridgidare stackable combo FLEB8200FSO. On mine this small part is number 144547100. Look for two black wires, one goes to H and the other to C. Disconnect both wires and no more buzzer!! Good Luck
Mar 29, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Dryer buzzer is SO LOUD - How can I adjust volume/turn off?
Buzzer mounted to back of control panel.
**UNPLUG POWER BEFORE REMOVING CONTROL PANEL OR TOUCHING -ANYTHING-!**
Located on left side of control panel, bolted to back. Small rectangular device with two connections and no associated button or dial.
Remove the panel and disconnect one of the leads. Fold the connector back against its wire, carefully and securely tape the connector with electrical tape so it cannot touch anything. Also tape the connector on the buzzer that you removed the wire from.
Re-assemble the control panel.
As with anything mechanical, hours of frustration trying to take something apart can be avoided by taking a few minutes at the beginning to look closely at how it is assembled.
Mar 01, 2009 | Frigidaire GLET1031 Top Load Stacked...
Frigidaire GLEH1642DS Front Load Stacked Washer/Dryer Logo
844 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
