Question about Refrigerators
I have a whirlpool refrigerator which I purchased in 1999. The model is WRN42RWG6. It has the freezer on top. During the last week we have noticed water leaking in the fridge section. There is a vent like opening on top part of fridge which the water is coming from. It is not always doing it and sometimes there appears to be a lot of water. Quite often the water freezes too. Would be appreciative if there was any advice as it's a great fridge and don't really want to upgrade just yet.
  • 159 Answers
SOURCE: Kenmore Side by Side Refrigerator 1999
It is normal for that to be warm but not hot. you need to make sure that the condensor coils under the refrigerator is free of dust. You can get to it by removing the back cover and clean it with a vacume. Also make sure the fan at the compressor is operating. and also clean the fan blades while your there. Doing this and making sure the fan is working should solve your problem. Also in the summer time when its hot and humid the refrigerator has to work longer and harder to keep it cold. so you may notice the front just a little warmer then usual, but it should not be hot that you cant touch it. God luck
Posted on Jul 12, 2007
SOURCE: Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Posted on Feb 03, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
SOURCE: Refrigerator section warm. Freezer section OK.
Most likely it's a defrost system problem. One of the heaters could be bad and that will cause the coils to freeze up reducing the amount of cold air the fan can push into the fridge. Sounds wierd but, trust me, that could be your problem. Mine did that two years ago.
Posted on Apr 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
We got a used whirlpool refrigerator with ice maker last year out of some houses that were being demolished. Was a good looking clean appliance and ran well. Last Saturday my husband got some ice out and...
kbyhybtmjd.gif Find defrost timer (#4) and advance it by placing screwdriver into slot. Do this till you here a click. Unit should advance into defrost after a few minutes it should go back to refrigerate.
Jun 12, 2011 | Whirlpool Refrigerators
We have a Kenmore Elite side by side refrigerator, model no. 53209, purchased in 2003. Recently the drain hole/hose to the drip pan beneath the freezer compartment has been freezing up, apparently during...
Good day,
It's become a common problem on newer machines with less frequent defrost cycles and for a shorter period of time.
The following clip, as you scroll down will see the most exotic procedure. You may not have to go that far.
Using a length of #14 bare copper wire, and wrapping it around the heater and inserting it into the drain hole will usually work. You will need to remove the heater to perform this process properly, and I prefer to wrap the copper close together, each wrap touching the last one. Your call.
kitchenaid-top-mount-refrigerators/" spwrap?>kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Your machine is a product of Whirlpool which makes many brands, all of them with the same basic system.
Oct 19, 2010 | Kenmore Refrigerators
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
LG French Door Model LFX 25960--Freezing in right crisper door
Have person who changed out you controlboard come back and recheck connections and controlboard itself.
Jul 26, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Whirlpool Side by Side Refrigerator
 it really needs to be checked in person, the last thing you need is an unreliable refrigerator.
it could be:
  •  defrost timer sticking in defrost too long
  • defrost timer not defrosting properly
  • icemaker heater staying on too long
  • among other things
let me know if you have any more details
Jul 06, 2008 | Whirlpool Refrigerators
Whirlpool top freezer leaking into refridgerator.
Sounds like you need to clean the drain again.. if Im understanding right you fixed it once already and lasted 3 weeks.. sound like it plugged up again.. make sure drip pan under evapurator is clean
Sep 24, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
149 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
