Question about Mitsubishi WS-55511 55" Rear Projection Television
WS-B55 - Remote doesn't respond, front panel partial response
Hi, last night I tried to turn my TV on with the remote but it did not work.
I turned it on from the front panel and that worked but the only other buttons that worked were "Device" and "Enter".
Device cycled thru the devices properly but when I hit "Enter" all it did was go to the next device.
I am able to power it off via the power button on the TV but once, that didn't even work. Then I hit device (just brought up the menu0 and then I was able to shut it off with the front panel.
I'm wondering if this is a software problem.
Any ideas?
Thanks in advance,
Joe
  • 2 more comments
  • Joeygates Jun 15, 2008
    Just to add, I also reset the system with the reset button a few times and nothing changes.
  • Joeygates Jun 21, 2008
    Just curious if anyone has any ideas about this at all. Mitsubishi has directed me to a service tech and I don't know if I want to go spending $500 to fix a TV I purchased just over 5 years ago for $2500 . . .
  • Joeygates Jun 22, 2008
    All fixed. Got my solution from:
    http://www.hdtvoice.com/voice/archive/in...
  • tfarron Aug 10, 2008
    the mitsubishi remote will not work with the tv. the volume icon is always on the screen. my direct tv remote will turn the tv on and off
Genius!! Thanks! I took a dry cotton towl and ran it across the keys on my front panel and whatever was stuck, became unstuck..The internet just saved me $150.
Posted on Aug 15, 2008
No power
replace the power supply board inside tv
Jan 30, 2013 | Emerson Televison & Video
My olevia LT23HVX does not power on
Try unplugging and replugging after waiting.
Jun 13, 2008 | Olevia LT23HVX 23 in. LCD Television
Hi i have an isis tv and have lost the manual to it. I can not get the tv to switch on, every time i turn the power on and try and use the remote to turn it on nothing happens and the led red light on the...
Hi can anyone please help me a have a isis tv only a year old was working fine last night aye want to put it on tonight and the red light flashes for a bit than comes on but no sound or picture what could it be the scream is just dark
Sep 13, 2011 | Televison & Video
MY REMOTE CONTROL DOES NOT WORK AFTER DARK
bdale
You may have IR interference at night because of other items you turn on at night. Try leaving everything off except your TV and receive, try your remote to make sure it functions. Then turn 1 item on at a time, try the remote to see if it works or stops working. Once it stops working, the last item you turned on is causing the interference. It is then a matter of relocating that item so it won't continue to interfere with the remote functions. I hope this helps.
Ray Calo
DISH Network
Nov 22, 2010 | DISH Network IR Remote Control
Last night I dropped the remote for my CLT1554 tv
Please reinstall batteries in remote and check.
If still does not work then remote circuit board could be damaged and new remote is an option.
Hope this info will help you.
Thanks.
Feb 14, 2010 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Mitsubishi wd60737. It will turn on. Remote does work. Sound does work. But, the video won't show. It just stays black. There is a solid red light when it is off. Tried to reset it and it still did the...
make sure u set ur output to AV u will find this on ur remote control or on front of ur tv set
in regards ur tv will not show a picture since ur last adjustment try to go to menu and follow instruction how to set the tv back to factory setting......this may give u ur picture back......if not call mitsubishi service centre and tell them about ur problem u have......i am sure they will help u
Nov 28, 2009 | Mitsubishi WD-60737 60 in. HDTV
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
HI, my remote for my Tv no longer works and it has been child locked, we have bought a universal remote but it will not work. Is there a way to unlock the child lock as we need to turn down the volume on...
Good Day, mallory3; Try unplugging the TV from it's a/c source (reset). If this a MIT"S: To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. Good Night & luck, big IRISH.
Aug 16, 2008 | Televison & Video
Weird remote action, no cable, worked fine last night.
called for reset on programming by Cox Cable. Worked...amazing!
Mar 10, 2008 | Sylvania 6432TE 32" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
244 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
