When i m starting my laptop S.M.A.R.T hard drive failure is showing.how 2 recover this warning ? this warning is showing since last 4 days.plz tell me the solution
    Problem Solver:
  • 16 Answers
Changing the hard drive is a last resort. action. Loose or defective hard drive data cable as well as data corruption can cause the same alarm. Disconnect and reconnect the data cable. Download seatools and run it. The Seatools long test is a better way of detecting a screwed hard drive
Posted on Nov 29, 2010
  • 32,281 Answers
If it gives a warning that the hard drive is about to fail, it means the hard drive will fail soon and that you should back up your data while you have a chance.
When the hard drive fails then you need to replace the faulty and install Windows on the new hard drive with the laptop's device drivers and your programs to get a working laptop again.
Posted on Nov 07, 2010
It wont record and it keeps displaying the message Warning: failed to open event log file c:dvtr\alarmlog\20110812\H2230 for writing It also says something about possible drive failure I have a DVR...
My own personal experience (which may or may not match other people or manufacturer expectations) tell me hard drives do not last forever. I have had, and worked on, computers since the 70's. Most of my drives last about 3 or 4 years. After that long, I usually replace them rather than wait for a notice that my drive is failing. My guess, and this is a guess as I do not have your drive to examine it, is your drive is either bad or going bad and you should replace it.
Dec 14, 2017 | Maxtor DiamondMax Plus 8 40 GB Hard Drive
Please tell how to reset my computer to factory defaults
If you Toshiba is a fairly recent laptop and there is a Restore partition on your hard drive.
To restore your Toshiba to "Out of the Box" condition then please click on this link and follow my instructions :-
http://www.fixya.com/support/r8248520-restore_toshiba_out_box_condition
Mar 11, 2011 | Toshiba Satellite L455DS5976 Notebook
I have a gateway t-1620 and on startup it says SMART Failure Predicted on hard disk 4: WDC WD2500BEVS-22USTO-(SI) WARNING: Immediately back up your data and replace your hard disk drive. A failure may be...
Hard drive going bad, you need to recover all your data as soon as possible. It is likely that the RSC has exceeded the space allocated to spare disc space, however, you can check this by downloading and running HDD tune (freeware) to ascertain the disc health and any bad sectors, if there are more than 2 bad sectors and the RSC on the health page is shown in red or yellow, the drive needs replacing
Jan 04, 2011 | Gateway T-1620 Notebook
Hi!im using a toshiba a210 laptop.i put it on some fews days ago it says "smart failure on hard disk 4-hitachi-(s1). warning:immediately back-up your data and replace your hard disk drive.a failure may...
Your drive is failing and you should back up any important data you need onto CD/DVD or an external USB device (hard drive/pen drive). The drive may keep working for a while but your system is warning you that it has detected a critical error with the drive and failure is imminent.
Jun 10, 2010 | Toshiba Satellite A215-S5822 Laptop
HP laptop will not recover or restore! HP
Run a system restore back to factory default setting.
Start system and hold down the f11 key till it rings a bell.
This will start the restore program.
Follow the system prompt. But remember to backup your documents and files.
Good luck.
Feb 04, 2010 | HP Pavilion dv6812nr Notebook
BLACK SCREEN WITH CURSOR NOW WITH A BLINKING LINE
Sounds liek your hard drive has failed, search ebay for this model of laptop with hardrive at end of yoru search, not 100 percent sure but im nearly 90 percent sure its hard drive failure.
Dec 03, 2009 | Gateway P-6313 Notebook
System board failure
You may need a new CMOS battery.
For now, you will most certainly need to reconfigure your BIOS as it is probably not recognizing your hard drive.
Your PC should tell you which key to use to enter your BIOS setup, such as ESC, DEL, F2 etc.  Press the appropriate key while booting to access the BIOS configuration.  From there, see if there is an option to set the hard drive to AUTO.
Also, it's possible that the BIOS is recognizing the hard drive, but your Master Boot Record (MBR) has been corrupted.  To fix this, insert your OS (windows) disk and load into a DOS command prompt via selecting the REPAIR option.  Once at your command prompt, type in FIXMBR, and press <ENTER>. It will warn that rewriting the MBR may cause problems...just continue.  Once successful, reboot your PC.
If that doesn't work, then you will probably need more help reconfiguring the BIOS, and may need to replace the small battery on your motherboard.
Jan 01, 2009 | R.A.M. Computers Compaq Presario 1075,...
ACER SMART failure
SMART means self monitoring and reporting tool, this is the option which performs certain test for the status of hard disk health, if its coming it means condition of your hard disk is not good, its better if you immediately back up your data and replace it, by the way you can also disable this warning through the bios, just disable the smart feature in hard disk
Nov 10, 2008 | Acer Aspire 3680 Laptop
Replace hard drive
You didn't ask any question ....but you already know the answer. The drive is most likely now a paperweight.
If you have critical data to recover, you can contact Drive Savers ...they're pricey, but they're good!
Hope this helps - remember to rate! :)
Oct 01, 2008 | Toshiba Satellite P15-S479 Notebook
Computers & Internet Logo
David Payne
David Payne
