Question about Mitsubishi Televison & Video
The green light on my wd-65c9 won't atop blinking an it stays at the welcome screen how do I fix this
  • Mitsubishi Master
  • 11,800 Answers
I'm assuming that you have performed the standard reset procedure: removed all cables from the tv, power it off for 1 minute; restart, power it of and restart with the Activity button pressed with the same result.
This behaviour is caused by the control processor which is unable to load the firmware. This in turn can be caused by only 2 things:
1. the firmware was corrupted by a power failure. It happens. The only way to solve this is to reload the firmware. Unfortunately the only one that can do that is a dealer .
2. the control processor itself is defective so the entire mainboard will have to be replaced.
This is a very recent tv, it might still be in the warranty period. In that case don't open it, call them, they should fix it for free.
Posted on Nov 07, 2010
When i turn my tv on the screen just stays black. You can hear the volume. I just replaced my bulb about a month ago. I took the bulb out again to see if it was blown and it wasnt. Does anyone know wh
send me a email slinteriors@yahoo.com and I will send you the info to retreve the error code to find out why the set is shutting down. Be sure to include the moodle number and symptoms with your email
Feb 10, 2013 | Mitsubishi WD-65C9 65" DLP HDTV
My WD-65c9 boots to welcome screen then shuts down with a flashing red LED.
42 is an error code for faulty "Lamp Sirocco Fan" part no. 299P321010. You have to replaced it with new one. I've saw it at shopjimmy.com ( http://www.shopjimmy.com/mitsubishi-299p321010-fan.htm )
Dec 15, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
Green status light stays blinking on the welcome screen
You need to go to mitsu's website and download the newest firmware update. It will come with instructions on how to install. This will fix your problem.
Mar 17, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
When you turn the TV on it stops at the blue Mitsubishi screen and the power button just blinks. You have to then unplug the TV to power down. Pushing the power button on the TV or remote will not power...
There is a software update that is available for some Mitsubishi dlp models. The wd-65c9 is one of them. When I experienced your problem, I went to the website, downloaded the update, and installed it on my tv and boom, its fixed. It's super easy, free, and takes a few minutes.
Jan 31, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
I HAVE A MITSUBISHI MODEL 65C9 THAT WHEN I PRESS POWER BUTTON AND GREEN LIGHT BLINKS STARTS TO LOAD UP AND THEN TURNS OFF WHAT IS THE PROBLEM?
You need to replace the main board, call Mitsubishi help line, they did not charge me a dime (If your TV is less than Yr old)
May 17, 2010 | Mitsubishi WD-65C9 65" DLP HDTV
Brand new mitsubishi wd-65c9. Pulled out of box and set up. Welcome screen comes on and then shuts off. Green light flashes 3 times, pauses, flashes 7 times. What does this mean?
It's a possibility that the lamp is bad. I don't mean to insult your judgment, however, as a professional tech I would have never purchased a DLP set. They have been headaches for the manufacturers as well as us techs since they hit the market. If at all possible I would return it and purchase an LCD set.
Nov 30, 2009 | Televison & Video
Televison & Video Logo
363 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
