Question about Panasonic RX-DS5 Boombox
Part Number for FM Antenna and source for the part
  • 4,234 Answers
Parts for this unit are available from encompass.com using part number: XEARR210CA-C. The cost is $6.22 plus shipping.
Dan
Posted on Nov 09, 2010
Testimonial: "Excellent feedback. Right on target."
How to install and external antenna to my Sony Dream Machine ICF-CD843V CD Clock Radio...
The dream machine has a ferrite bar antenna built in to it for AM and the power cord functions as an FM antenna.
You really don't want to fiddle with the antenna but can adjust reception by moving the unti away from any large metal objects near it.
You should have the power cord fully extended and not looped up into a bundle.
You also want to distance it from any sources of interference like electric motors or other sources of radio interference.
By "large" I mean anything the size of a microwave oven and larger.
Feb 11, 2016 | Sony Audio Players & Recorders
What is the video single output VHF FM UHF 12db
That sounds like the description of a broadband amplifier. It likely has "F" type (cable-coax) connectors and a power cord.
Commonly used to increase the signal level of TV cable to compensate for inserting a signal splitter, or in some cases to increase the signal level from an antenna, typically outdoor TV or FM radio antenna, so it is connected between the signal source (antenna, or cable) and receiver with antenna as input and receiver connected to the output of this little box. The gain (amplification) it provides is 12 dB, so the output is more than 3 times the input.
Oct 03, 2014 | Radio Communications
Rca rt 2770 programming. My fm radio stations
You can manually program a station by pressing AM/FM to get to the correct radio band. Then tune in a station with the Tuner +/- (the left/right arrow) buttons on the remote. Next press Memory (just below 7) and then a number on the keypad. The number must be entered before the Program Preset number stops blinking. (For FM you can use some 2 digit numbers.) To scan through the stations in memory use the Channel +/- buttons on the remote or the Next/Previous track buttons on the RT2770. You could fill all of the memory slots automatically by pressing and holding the AM/FM button for two seconds. The unit will store the stations that it tunes in in order until the memory slots are full. Note: you do need to have the FM antenna and AM loop antenna connected (and extended for the FM antenna).
Retrevo has the manual for the RCA RT2770 available here: http://www.retrevo.com/support/RCA-RT2770-Home-Theater-Systems-manual/id/2869dj191/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Apr 30, 2014 | Audio Players & Recorders
Coaxial FM antenna
Radio Shack has an
adapter catalog number 278-0291. It takes some effort to push the 278-0291
adapter onto the FM UNBL 75 ohm terminal so wait until you have the 278-0291
installed before you connect your 75 ohm coax on to your new adapter.
This will resolve your FM screw on F connector antenna interface issue.
I see others trying to
help suggest using a 300 ohm to 75 ohm transformer match unit, this isn't what is needed. Your receiver antenna input IS a 75
ohm input.
May 22, 2013 | Sony MHC-GX450 CD Shelf System
I need an antenna for the sony Mico Hi Fi CMT-FX300i
Do you need the AM loop antenna or the FM antenna? The loop antenna is available for $11.27 from http://www.partstore.com/Model/Sony/Sony/CMTFX300I.aspx . This is part number, 1-754-399-11 . The antenna is also available from Amazon.com for $15. I do not know of any sources for the FM antenna.
I hope this helps.
Nov 26, 2012 | Sony CMTFX300I - Cmtfx300i
How do i hook up an antenna to the pioneer sx-950
There are two antenna sources on the Pioneer SX-950.
Both of these outputs are located on the rear panel of the receiver. The AM is a permanent mount. The FM is standard RF/Coax which will run to your antenna.
Antenna Inputs: FM 75 ohm, FM 300 ohm
Am Ferrite Bar Antenna
Hope this helps,
TechGuy21
A
s
Jul 04, 2011 | Audio Players & Recorders
Am/fm radio stations not clear... I have the AM antenna attached... but there is no attachment for FM
First of all check for any nearby source of interference.....Move your unit away from all computers, fluorescent lights, neon lights, microwaves, cell phones, and cell phonemag-glass_10x10.gif chargers. These devises tend to produce noise in the medium frequency band, where AM radio is broadcast.
If the unit plugs into the wall with a nonpolarized plug (where both prongs are the same size), try reversing the plug inmag-glass_10x10.gif the outlet. Moving the plug to another outlet might help, too.
check for fault in the antenna lead, (common) or bad earth on the antenna to body
If you don't have an antenna connected to your FM receiver,With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 2 If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
  • Step 3 If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
  • Step 4 If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
  • Step 5 Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
  • Read more: How to Strengthen FM Radio Reception | eHow.com http://www.ehow.com/how_114024_strengthen-fm-radio.html#ixzz0u9nhGXAL
    If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters. Make sure to Switch from stereo to mono.
  • Step 4 With a receiver or tuner, connect a wire-loop or T-shaped dipole FM antenna to the back of your unit. Move the antenna until you get the cleanest signal. Use a signal-strength meter or display to gauge signal strength if your unit has one.
  • Step 5 Alternatively, upgrade to a third-party passive or powered antenna.
  • Step 6 Install a rotatable roof antenna for the best possible reception. Connect your unit to an existing televisionmag-glass_10x10.gif roof antenna for the next-best alternative.
  • Read more: How to Improve FM Reception | eHow.com http://www.ehow.com/how_5554_improve-fm-reception.html#ixzz0u9oTaz4Y
    Jul 19, 2010 | RCA RT2760 System
    2007 Camry: I can't receive clear radio channel in camry 2007 ...
    if you have a factory radio, then chance are you antenna is amplified (even if you don't have an antenna that goes up in the back). The fuse for the antenna amplifier could have blown or the amplifier itself my have gone bad. It could also be your radio but, i would check those things first... Just a side note: i don't know of any stations that around me that aren't odd numbers 92.3 fm,95.5 fm,100.3 fm. Where you able to tune it to 100 fm before?
    Apr 28, 2010 | Cars & Trucks
    How do you install this thing
    Hello cmiller23606,
    It installs in a Toyota Yaris or any other vehicle exactly the same way. The device is an FM modulator and has no vehicle specific wiring. You do need a 12V source from the vehicle and a ground connection as well as access to the radio antenna jack.
    Connect power and ground to the 40" wire with the inline switch. Be sure to observe polarity. Piggyback the modulator directly onto your in dash receiver by removing the antenna lead from the receiver and plugging it into the FMMOD01. Then run the 21" cable from the modulator to the now vacant receiver antenna jack. Mount it with screws, double sided tape, plastic wire ties, velcro, or permanent glue. Using the side-mounted slide switch, select an FM frequency of either 87.9 or 88.3, plug a source (CD player, minidisc, videocassette or DVD player, iPod, MP3 player, or any other source with a minijack or headphone output).
    Tune your in dash receiver to the selected FM frequency and you're ready to go.
    Hope this helps.
    Aug 08, 2009 | Scosche Industries Scosche Audio...
    Philips MC156- makes a loud hissing sound when switched on?How do i get rid of this and get the system working?
    Do you mean audio hissing sound or is there smoke coming out the back?
    In what sources does the hiss occur?
    Audio hiss with the FM tuner selected would mean it's between stations or you don't have an antenna. Try tuning around the band with an antenna attached.
    Apr 04, 2009 | Audio Players & Recorders
    Panasonic RX-DS5 Boombox Logo
    90 people viewed this question
    Top Panasonic Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
