Question about Dryers
Suggested gas coil problem MDG7600AWW
I too have this problem and wish to know which of the two coils you think should be replaced, if only one... the "main - 2 terminal" or the "pilot position - 3 terminal" coil?
Thank you in advance for your reply.
  • whtchagnnado Jun 16, 2008
    Thanks Guru. I asked because I saw them listed with separate prices for each.
  • 164 Answers
They come in a package of two, so my suggestion is change them both. If one i shot the other one might not be that far behind.
Posted on Jun 15, 2008
Maytag atlantis model #mdg7600aww how do i light pilot
This gas dryer uses automatic ignition. Their is no pilot. The gas valve assembly consists of a glowbar/ignitor, a flame detection sensor and a pair of coils all cleverly wired in a complex series circuit. When the fuse allows the control to flow power to the gas assembly all of the gas assembly components are energized. The coils cannot open the valve however as long as the ignitor is glowing. When it gets red hot it heats the bimetal inside the flame detector which shuts off the power to the ignitor. When the ignitor glows it holds open one of the gas coils. The other gas coil has enough juice for it to open, then ignition occurs. Depending on how many clothes is in the drum and how wet they are detirmins a burn period. With nothing in the drum it heats up to temp promptly and therefore the gas stays on a shorter period of time. So what can go wrong? The fuse mounted next to the control on the blower housing will melt if the blower wheel is wobbly and worn out or their is a lint build up causing air flow blockage. The control stat might be bad (doubtful) unless it ain't shutting down and is melting the fuse. If power is indeed getting to the gas assembly I would check the sensor first. if it is open circuit no power will get to the ignitor. If that is fine check the ignitor for continuity. Note: If it works a little but quits, replace them solenoid coils on the assembly. When they get aged they tend to quit when hot. My home movie of how it works:
Nov 19, 2012 | Maytag Dryers
2000 s10 misfires
ONE DO A COMPRESSION TEST ANYTHING OVER 120LB ITS OK TWO DO A FUEL INJECTION SERVICE CAN ONLY BE DONE AT A SHOP COULD BE DIRTY INJECTORS OR BAD 1 OR 2 INJECTORS TRY TO GET CODES LET ME KNOW WISH CODES GO TO AUTO ZONE THEY WILL DO FOR FREE GET CODES OK LET ME KNOW ILL HELP YOU DO NOT AD ANYTHING TO YOUR GAS TANK NO FUEL CLEANERS FOR ANY RESON OK
Nov 18, 2012 | Cars & Trucks
The glow plug will light up but the gas does not come out. I think it might be a solenoid.
Yep. If the ignitor is working properly and the dryer won't light, then it is most likely faulty gas valve coils. These electrical coils are right above the gas valves. These solenoids, when energized, open the gas valves and permit the burner to light. If any are suspected of being faulty, it is recommended that both (all) be replaced at the same time. Hope this helped and best wishes.
Aug 30, 2009 | Dryers
Glow plug lights but does not fire gas everything
This is most likely faulty gas valve coils. These electrical coils are located just above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If faulty, the gas valves cannot open and the burner cannot light. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at once if any are suspected of being faulty. Hope this helped and best wishes.
Aug 08, 2009 | Dryers
GAS WILL NOT COME ON
The gas valve coil solenoids are most likely defective. The coils should be right above the gas valves. They are hard to test, so both coils should be replaced at the same time. When working properly the coils open the gas valves when the solenoids are energized. Hope this helped and best wishes.
Jul 28, 2009 | Dryers
Dryer worked well until recently. Igniter glows
I would take a look at the gas coil solenoids. The gas coils are right above the gas valves. They are black electrical coils. When energized, the coils open the gas valves. If one or more of the coils is defective (bad solenoids), then the gas valves won't open and the gas cannot ignite. Because it's difficult to test the coils, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
Maytag MDG7600AWW not staying hot
Hi, It sounds like that the coils on top of the gas valve are not opening the valve later in the cycle. They get weak enough ovwer heat and will not open the valve. You can listen for the ignitor to click on and then you can hear the gas ignite. If late in the cycle you hear the igniter click and then no gas ignition, change the coils.
You should also make sure the vent going to the outside is clear of any lint or kinked.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 13, 2009 | Maytag MDG7600AW Gas Dryer
Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
Mar 02, 2009 | Maytag Dryers
Maytag Atlantis MDG7600AWW Not Heating
the gas coils have a problem. as the dryer heats p the coils on the gas valve are failing causing the dryer not to heat. replace the coils and you should have no problem
Oct 22, 2007 | Dryers
Dryers Logo
Top Dryers Experts
