Question about Toshiba Satellite A15-S127 Notebook
I have a Toshiba A15-S127 I am changing the CDR/DVD to a DVD-R/CDR my new DVD drive is cabke select and my hard drive is set to master. I jumped my hard drive to cable select and installed the new DVD-R and Windows doesen't see it. On boot up I see a IDE #1 error. Do I need to deleate my drivers and which one. The new DVD-R is suppose to work for my laptop it is a Toshiba as well.
  • 263 Answers
SOURCE: Toshiba Satellite A15-S127 DVD driver
thats may be because you don't have a dvd .is just a cd drive
Posted on Dec 27, 2007
  • 108 Answers
Yes there is a way. If you are tech savy, get a screw driver open the Memory compartment at the back of your laptop. You will find the BIOS battery there get it out and thus left it for some time without any battery (Laptop battery or BIOS battery). Hopefully you will also find the reset button near the BIOS battery. Rest the BIOS. After reinstalling the batteries you might require to select some setting but this method will reset you BIOS password.
But a piece of advice for you, if you are not a tech savy, get it done by a technician than byyourself.
Posted on Feb 09, 2008
  • 7 Answers
SOURCE: BIOS Battery Location of Toshiba Sattelite A15-S127
1. Remove the battery (side latch release) and hard drive. The only screw that holds it down is marked F-4 on the cover. (look for the panel with the 2" circle, that is the HD)
Use the white pull tab to move it left then upwards. It should move with little effort. Be careful not to loose the screw from the HD panel.
2.Remove all screws annotated F6 from the bottom bezel with a Pt. 2 screwdriver. (from my count there was less that a 15 )
Depending on the screwdriver, there are times where you might have to push the screwdriver down a bit to get in contact with the thread. Just be careful not to strip the threading.
3.Remove the "B25" screw located near the heat sink-fan vent. Somewhat carefully take your hand, and lift the bottom bezel up enought to disconnect (about 1-2 inches from surface) the battery with your index and midde finger. Look at they way the battery is run, and seated in the plasic clips.
With the bottom semi-open, plug in the replacement battery, and re-seat it in underneath the white ribbon cable, and clips on the housing per the original.
4. Replace all screws (less than a ton).
5. Re-seat the hard drive, by sliding it in first with the metal tab under the plastic housing, to the left, then puling it to the right. Replace the panel with the one, shorter, F-4 screw. Reseat the battery.
6. Return your model car with reciept. If a reciept cannot be found, use it for store credit.
If you wish to test the battery, simply unplug it and remove the battery for 30 minutes. Then power it on with only the A/C adapter. If no CMOS screen appears, you are good to go.
http://www.tomshardware.com/forum/247842-30-replace-cmos-battery-toshiba-satellite
Posted on May 06, 2009
  • 1684 Answers
SOURCE: s-video tv out for TOSHIBA A15-S127
Hello Earl,
The device you need is called a scan converter, they are available from www.newegg.com search for avermedia. Please keep in mind, these adapters will convert from pc to tv but the picture in now where near as clean and crisp, especially for text. I think your best be would be to spend just a little more and get a 19-22" LCD monitor.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Posted on Jun 18, 2009
Santhosh_7
  • 233 Answers
SOURCE: led lights up no display. perfect thru vga
The issue could be due to the corrupted display drivers, battery, hard disk, etc.
I recommend you to follow the steps in the below link:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Also if you have an extra computer, use an S video cable and connect it from your laptop to the computer and start your laptop.
Check if you are able to get the display on the computer, if you are able to view the laptop's display on your computer then reinstall your video drivers from Device Manager.
Update even the BIOS of your laptop.
To reinstall display drivers go to Device Manager, right click the display device and select Update driver.
Update BIOS only if any new version of it is available in the Toshiba support website.
If the BIOS is flashed to older version, your notebook may not work for ever.
You can also install drivers from Toshiba Support website:
www.csd.toshiba.com
You must be able to get the display after reinstalling display drivers.
Posted on Jun 29, 2009
Error loading operating system amessage appear on toshiba satellite A15-S127 and operating system cd on dvd and it didn't boat from dvd what can i do? or how can i enter setup
So you have a potential problem with the hard drive and a known problem with the optical drive. Replace the optical drive first: it's easy (one screw at the bottom, another one underneath the keyboard - these are the only 2 screws holding the optical drive in). You can buy a replacement drive, new or used, on eBay for $10 - $20 delivered. After that, you should be able to figure out if the hard drive's problems are OS related or HW failure. HDD's are cheap, too. This model uses 2.5" ATA IDE drive (30 or 40G or you can go larger), figure 50 cents to 75 cents per gigabyte, and you'll be okay. Just don't pay tourist prices for these things....
Apr 21, 2011 | Toshiba Satellite A15-S127 Notebook
HI, my toshiba a15-s127 won't power up. It will begin to boot, the progress bar at the bottom of the screen appears, then after a few long seconds the laptop seems to re-boot. The error message is (FILE IS...
You have a serious problem. There may be another solution, but I recommend reinstalling Windows. You will need to backup everything on the hard drive, which will require a second computer and some way to connect your current drive to it. Once that's done, get an install disc for the version of Windows you want to install. Power up the computer as much as you can, put the disc in the drive, then restart. An option to boot from the CD should appear. If it doesn't you need to change some BIOS settings first. That involves pressing whatever key is listed at the very first startup screen, and scrolling through the text-only menus to change the preferred order of the boot devices. Set the CD drive to the first spot in the list. Once you can boot from the disc, the installer will take care of the rest and can walk you through the installation. Good luck!
Mar 03, 2011 | Toshiba Satellite A15-S127 Notebook
How i format a15-s127 notbook because it's corrupt.
1. Enter the BIOS - the key to press is written on the main screen, most likely F1.
2. In there change the boot order - put the cd first and the hard disk second - follow the instructions on the screen on how to do it.
3.Boot from your recovery disks and during install choose a full format.
Feb 13, 2010 | Toshiba Satellite A15-S127 Notebook
What is another model number that would work for my a15-s127
On Toshiba’s web sit it is listed as 411405 A15-S127. I did not find any other reference. Good Luck
Jul 28, 2009 | Toshiba Satellite A15-S127 Notebook
Unable to recognize new DVD drive
sounds like it's missing a power source. Re-check to ensure both a power source and cable are firmly in place.
Apr 25, 2009 | Computers & Internet
Hard drives!
your harddrive is standard 30 gb on ide connection and u can ad a new hard drive on your notebook up to 250 gb ide but u will have to format the system brandnew
Jan 01, 2009 | Toshiba Satellite A15-S127 Notebook
Toshiba hard drive craddle
you can go to www.drivesolutions.com
thats where I get all my parts for my toshiba, but they usually have hard drive parts for all major brands.
Sep 08, 2008 | Toshiba Satellite A15-S127 Notebook
Dec 27, 2007 | Toshiba Satellite A15-S127 Notebook
Change of HD problems
check if the hard drive you bought is an IDE or SATA hard drive. if it is SATA you cant use it on your laptop. it should be IDE
Dec 11, 2007 | Computers & Internet
Toshiba Satellite A15-S127 Notebook Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
